Incorrect pump RPM (Asus ProArt X670E-Creator WiFi)
i have  vpp pump in custom  watercooling
asus proart x670e
amd 7950x3d
 pump is to 100% 4450rpm  after few hour pump in display have 2250rpmin aida but flowmeter don't change  and other sensor say 4450rpm
if i reboot pc aida say 4450rpm again
asus proart x670e
amd 7950x3d
When the anomaly occurs, please check the pump RPM using another software like HWMonitor or HWiNFO.
  • Fiery changed the title to Incorrect pump RPM (Asus ProArt X670E-Creator WiFi)
the rpm is good with other app hwinfo fans control
i have debitmeter if i turn to 50% flux is slow but no flux is normal  if a problem with aida only
the bug is appear after 12h pc on or not...
