raylau Posted December 28, 2013 Posted December 28, 2013 Whenever I run the System Stability Test, if I enable the Stress GPU(s) option and then disable it, even after I disable the option to stop running the GPU test, my GPU stays stuck at a high clock speed (1005MHz instead of 324MHz at idle). The only way to fix this is to go into Device Management, disable, then re-enable. It will still come back at 1005MHz but will settle back down to 324MHz within a few seconds. (Or, of course, reboot.) I have an EVGA GTX 780Ti SC ACX (03G-P4-2884-KR) running under Windows 8.1 Pro. Quote
Fiery Posted December 28, 2013 Posted December 28, 2013 AIDA64 doesn't alter the P-States (Performance States) configuration of the video driver or the video card itself, so if the clock gets stuck, it is the fault of the video driver (ForceWare).Regards, Fiery Quote
raylau Posted December 28, 2013 Author Posted December 28, 2013 Thanks for the info. Alas, I don't think I know enough about aida64's GPU test to properly report this to nvidia. Other GPU tests like furmark, heaven, valley, 3d mark, do not show this interaction. Nor does ending a folding@home session, so it is not specific to true 3d vs GPU compute only loads. Well, I suppose it is what it is, but if the issue also shows with your lab nvidia cards, perhaps help let nvidia know? Other than this and an occasional access violation when changing prefs (can't reproduce even semi reliably though seen it 3 or 4 times, or I would report it), aida64 is one of the most stable and useful hardware info type tool avail! Quote
Fiery Posted January 6, 2014 Posted January 6, 2014 We've done a few test runs with various GeForce cards, and it seems GPU clock gets stuck at 3D rates only when you keep the AIDA64 System Stability Test running and just untick the GPU subtest. That keeps the OpenCL context still open, although not executing any OpenCL kernels (computing tasks). In such case ForceWare keeps the GPU running at high clock speeds for whatever reason, and only lets the clocks drop down to power saving (low) rates when you press the Stop button on the System Stability Test window. That's because when you push the Stop button, AIDA64 closes and invalidates the OpenCL context. While AMD Catalyst drivers vary GPU clocks based on actual GPU load (utilization), ForceWare drivers seem to work based on OpenCL/Direct3D/OpenGL contexts. That's just a different approach, although quite frankly we would prefer to have drivers all work by GPU utilization Quote
