eskimo718 Posted January 30, 2025 Posted January 30, 2025 Its just stuck showing the values in Mbps, even if you change it to Gbps or MBps or Gb/s. Changing the units value works in download/upload rate Quote
Solution Fiery Posted January 31, 2025 Solution Posted January 31, 2025 On 1/30/2025 at 1:49 AM, eskimo718 said: Its just stuck showing the values in Mbps, even if you change it to Gbps or MBps or Gb/s. Changing the units value works in download/upload rate We will fix that it in the next AIDA64 beta update. 1 Quote
