VintageOffice Posted February 23, 2025 Posted February 23, 2025 Hi, Is there any option to open the sensor panel manager without right-clicking on the panel itself? My panel is a secondary screen, in Windows it's placed on the upper right corner of all displays and cursor ease is disabled so one can never access the display with the cursor. To modify something, I have to do many steps in settings to get the ability to edit the sensor panel layout. Why isn't there a simple button so open the sensor panel manager? Or am I missing something? Jeroen (Sorry, should have been posted in the Sensor Panel topic) Quote
Surjeet Posted February 23, 2025 Posted February 23, 2025 4 hours ago, VintageOffice said: Hi, Is there any option to open the sensor panel manager without right-clicking on the panel itself? My panel is a secondary screen, in Windows it's placed on the upper right corner of all displays and cursor ease is disabled so one can never access the display with the cursor. To modify something, I have to do many steps in settings to get the ability to edit the sensor panel layout. Why isn't there a simple button so open the sensor panel manager? Or am I missing something? Jeroen (Sorry, should have been posted in the Sensor Panel topic) In the latest AIDA64 update added Ctrl+M keyboard shortcut on the SensorPanel to let you open the SensorPanel Manager without using the right-click context menu. 1 Quote
VintageOffice Posted February 23, 2025 Author Posted February 23, 2025 2 hours ago, Surjeet said: In the latest AIDA64 update added Ctrl+M keyboard shortcut on the SensorPanel to let you open the SensorPanel Manager without using the right-click context menu. Thanks for your quick reply. This needs the sensor panel to be set to the other display before it can be accessed. Display 2 is the sensor panel display. It is placed in the upper right corner of the main display. The option to ease the cursor movement to switch between displays is turned of. So you can't access the second display with the mouse cursor. Shortcut key Ctrl+M doesn't open the Panel Manager when AIDA64 is opened/the active window. I'm using version 7.60.7300. Quote
Surjeet Posted February 24, 2025 Posted February 24, 2025 I thought regarding the same post sending you mine message here. I completely understand your point, and I believe this could be a great feature request for the AIDA Developers! You might want to share your message or post with Fiery—he's an amazing admin who can address and help bring such requests to life! Quote
Fiery Posted February 25, 2025 Posted February 25, 2025 On 2/24/2025 at 4:13 PM, Surjeet said: I thought regarding the same post sending you mine message here. I completely understand your point, and I believe this could be a great feature request for the AIDA Developers! You might want to share your message or post with Fiery—he's an amazing admin who can address and help bring such requests to life! @VintageOffice We've added a new hot key entry to open the SensorPanel Manager. You can find it in AIDA64 / Preferences / Hardware Monitoring / Hot Keys. Please check the following new beta update of AIDA64: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. 1 Quote
VintageOffice Posted March 1, 2025 Author Posted March 1, 2025 On 2/25/2025 at 7:31 PM, Fiery said: @VintageOffice We've added a new hot key entry to open the SensorPanel Manager. You can find it in AIDA64 / Preferences / Hardware Monitoring / Hot Keys. Please check the following new beta update of AIDA64: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. Yes!!! There's an extra Hot Key setting for the Sensor Panel Manager and it works like a charm. Thank you. Quote
Fiery Posted March 1, 2025 Posted March 1, 2025 9 hours ago, VintageOffice said: Yes!!! There's an extra Hot Key setting for the Sensor Panel Manager and it works like a charm. Thank you. Thank you for your feedback! Quote
