xtwguw Posted February 24, 2025 Posted February 24, 2025 My AX206 display panel is experiencing issues. I set the refresh rate to 1 second in AIDA64, but the panel refreshes every 2 seconds, resulting in a jelly-like effect and unsmooth refresh. lcd dump.txt Quote
Fiery Posted June 6, 2025 Posted June 6, 2025 On 2/24/2025 at 4:36 PM, xtwguw said: My AX206 display panel is experiencing issues. I set the refresh rate to 1 second in AIDA64, but the panel refreshes every 2 seconds, resulting in a jelly-like effect and unsmooth refresh. lcd dump.txt 3.96 kB · 4 downloads Check the USB connection of your display. You may want to try it with a different cable or different USB port. In most cases that helps to fix the slow updates. Quote
