123c123 Posted March 1, 2025 Posted March 1, 2025 On POCO M6 pro 4g does not correctly show the remaining charge in mAh. Quote
Fiery Posted March 1, 2025 Posted March 1, 2025 12 hours ago, 123c123 said: On POCO M6 pro 4g does not correctly show the remaining charge in mAh. Thank you for your feedback. Please note that on many devices the standard Android Battery API is inadequately implemented, and fails to provide proper charge counter information for the battery. If you want, you can hide the incorrect charge counter information from the Battery page by unchecking the charge counter option in the AIDA64 Settings. Quote
Aleksey_21 Posted March 4, 2025 Posted March 4, 2025 Здравствуйте, на OnePlus 13r аккумулятор отображается как Li-ion, хотя тут установлен аккумулятор SIC (кремний-углеродный) Quote
Fiery Posted March 4, 2025 Posted March 4, 2025 5 minutes ago, Aleksey_21 said: Здравствуйте, на OnePlus 13r аккумулятор отображается как Li-ion, хотя тут установлен аккумулятор SIC (кремний-углеродный) SIC is still based on Li-Ion technology. Quote
Crazin26 Posted March 15, 2025 Posted March 15, 2025 На Poco x6 pro не корректно отображается заряд и температура, она застыла на 56% и на темп на 30.7, можно это как по пофиксить? Quote
Fiery Posted March 16, 2025 Posted March 16, 2025 16 hours ago, Crazin26 said: На Poco x6 pro не корректно отображается заряд и температура, она застыла на 56% и на темп на 30.7, можно это как по пофиксить? Please avoid posting a single issue into multiple topics. I've replied you in your own topic. Quote
