beas62 Posted March 15, 2025 Posted March 15, 2025 I've been using AIDA64 for years, but with my new subscription and updates, I've lost the ability to monitor fans. Note that the fans show up in MANY free and open-source programs (Speedfan, HWInfo, etc., just not AIDA. Fan data comes from IPMI on my ASUS WRX80E Sage Wifi II. AIDA does "see" IPMI and can actually display IPMI logs, but there is no way to select the fan sensors for OSD or in-app display. Using the latest Beta after the stable did not work. v7.60.7311 Any fixes? Thanks. Quote
Fiery Posted March 16, 2025 Posted March 16, 2025 16 hours ago, beas62 said: I've been using AIDA64 for years, but with my new subscription and updates, I've lost the ability to monitor fans. Note that the fans show up in MANY free and open-source programs (Speedfan, HWInfo, etc., just not AIDA. Fan data comes from IPMI on my ASUS WRX80E Sage Wifi II. AIDA does "see" IPMI and can actually display IPMI logs, but there is no way to select the fan sensors for OSD or in-app display. Using the latest Beta after the stable did not work. v7.60.7311 Any fixes? Thanks. In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
beas62 Posted March 18, 2025 Author Posted March 18, 2025 On 3/16/2025 at 3:08 AM, Fiery said: In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Thanks, Fiery. Sensor dump attached. isasensordump.txt Quote
beas62 Posted March 26, 2025 Author Posted March 26, 2025 On 3/16/2025 at 3:08 AM, Fiery said: In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery isasensordump.txt Quote
Fiery Posted March 27, 2025 Posted March 27, 2025 On 3/26/2025 at 2:50 AM, beas62 said: isasensordump.txt 20.12 kB · 0 downloads Thank you! That seems to be a motherboard that should be already 100% supported by the hardware monitoring module of AIDA64. Please check the content of the Computer / Sensor page of AIDA64. If you cannot see the sensor readings for your motherboard listed properly there, then please post a screenshot (or full copy-paste) of the Computer / Sensor page to let us check it out. Quote
beas62 Posted March 27, 2025 Author Posted March 27, 2025 8 hours ago, Fiery said: Thank you! That seems to be a motherboard that should be already 100% supported by the hardware monitoring module of AIDA64. Please check the content of the Computer / Sensor page of AIDA64. If you cannot see the sensor readings for your motherboard listed properly there, then please post a screenshot (or full copy-paste) of the Computer / Sensor page to let us check it out. Thanks for checking. As you can see from the sensor page, the only fans detected are the GPU fans. All fans are set to PWM and report accurately in IPMI. I'm sure there's a setting somewhere I'm missing, but haven't found it yet.. Quote
Fiery Posted March 31, 2025 Posted March 31, 2025 On 3/28/2025 at 12:40 AM, beas62 said: Thanks for checking. As you can see from the sensor page, the only fans detected are the GPU fans. All fans are set to PWM and report accurately in IPMI. I'm sure there's a setting somewhere I'm missing, but haven't found it yet.. Thank you! It's very strange, your motherboard doesn't work at all like typical Asus desktop motherboards. Please send us one more dump: in AIDA64 please press Ctrl+D --> Sensor Debug --> Embedded Controller Dump. Thanks, Fiery Quote
beas62 Posted April 1, 2025 Author Posted April 1, 2025 8 hours ago, Fiery said: Thank you! It's very strange, your motherboard doesn't work at all like typical Asus desktop motherboards. Please send us one more dump: in AIDA64 please press Ctrl+D --> Sensor Debug --> Embedded Controller Dump. Thanks, Fiery It is not typical in my experience either. It's designed as a hybrid workstation/server board so seems a lot is offloaded to BMC and IPMI. Not much to the ecdump, but here it is. ecdump.txt Quote
Fiery Posted April 1, 2025 Posted April 1, 2025 14 hours ago, beas62 said: It is not typical in my experience either. It's designed as a hybrid workstation/server board so seems a lot is offloaded to BMC and IPMI. Not much to the ecdump, but here it is. ecdump.txt 2.18 kB · 0 downloads Thank you! Can you please repeat the EC Dump and as much as possible, capture the list of IPMI fan RPMs in the same time as the EC Dump is being performed? We may find some fans in the EC region that way. Quote
beas62 Posted April 2, 2025 Author Posted April 2, 2025 12 hours ago, Fiery said: Thank you! Can you please repeat the EC Dump and as much as possible, capture the list of IPMI fan RPMs in the same time as the EC Dump is being performed? We may find some fans in the EC region that way. Thank you, Fiery. The screenshot shows the fan speeds from IPMI and the dump is attached. Regards.. ecdump2wfanspeeds.txt Quote
beas62 Posted April 12, 2025 Author Posted April 12, 2025 Was that not what you needed? Let me know. Best regards, Jerry. Quote
Fiery Posted April 13, 2025 Posted April 13, 2025 19 hours ago, beas62 said: Was that not what you needed? Let me know. Best regards, Jerry. Yes, thank you! We've found 2 thermal readings and 2 fan RPM readings in the main EC block, so please check if it works already about those items in the latest AIDA64 beta update: https://www.aida64.com/downloads/latesta64xebeta Using that build please repeat the EC Dump since we've added dumping of 7 other EC blocks as well. We're hoping to find the missing fans in the additional blocks. Quote
beas62 Posted April 13, 2025 Author Posted April 13, 2025 5 hours ago, Fiery said: Yes, thank you! We've found 2 thermal readings and 2 fan RPM readings in the main EC block, so please check if it works already about those items in the latest AIDA64 beta update: https://www.aida64.com/downloads/latesta64xebeta Using that build please repeat the EC Dump since we've added dumping of 7 other EC blocks as well. We're hoping to find the missing fans in the additional blocks. Hello, Fiery. The SOC_Fan and Chipset_Fan are now visible in the sensor list under cooling fans. Below are the remaining fan speeds along with the EC dump. Good luck! ecdump3wfanspeeds2.txt Quote
beas62 Posted April 30, 2025 Author Posted April 30, 2025 Hopefully, we'll see my other fan speed sensors in the dump data. Quote
beas62 Posted May 3, 2025 Author Posted May 3, 2025 Okay, no response in three weeks. I can't expect any more support from Aida64? If not, just say so. I'll have to go spend money on a replacement. Quote
Fiery Posted May 4, 2025 Posted May 4, 2025 18 hours ago, beas62 said: Okay, no response in three weeks. I can't expect any more support from Aida64? If not, just say so. I'll have to go spend money on a replacement. I'm sorry for the late response. As you can see, we haven't released a new beta build in 3 weeks. It's only because we're working extremely hard on the next generation of AIDA64 that includes major changes and improvements. We're rolling out the first beta build of the new generation in a few days from now. I'll also update you on the missing fans issue soon too. Thank you for your patience. Quote
beas62 Posted May 4, 2025 Author Posted May 4, 2025 1 minute ago, Fiery said: I'm sorry for the late response. As you can see, we haven't released a new beta build in 3 weeks. It's only because we're working extremely hard on the next generation of AIDA64 that includes major changes and improvements. We're rolling out the first beta build of the new generation in a few days from now. I'll also update you on the missing fans issue soon too. Thank you for your patience. Thank you for the update. I know a new build is a challenge. Quote
Fiery Posted May 5, 2025 Posted May 5, 2025 22 hours ago, beas62 said: Thank you for the update. I know a new build is a challenge. I'm afraid we cannot find the rest of the fans in the EC space Quote
beas62 Posted May 6, 2025 Author Posted May 6, 2025 10 hours ago, Fiery said: I'm afraid we cannot find the rest of the fans in the EC space Okay. Thanks for trying. Quote
