BaconFox Posted March 20, 2025 Posted March 20, 2025 It would be helpful to be adjust the number of decimals shown for flow sensor readings, similar to Voltage and current. Thank you! 1 Quote
manuuuu400 Posted August 21, 2025 Posted August 21, 2025 This would help me a lot as well, decimals are pretty useless on my sensor panel. Thanks. Quote
Fiery Posted August 23, 2025 Posted August 23, 2025 On 3/20/2025 at 2:05 AM, BaconFox said: It would be helpful to be adjust the number of decimals shown for flow sensor readings, similar to Voltage and current. Thank you! @manuuuu400 We've implemented the requested new option (Decimal digits for flow sensors) in the latest AIDA64 beta update available at: https://www.aida64.com/downloads/latesta64xebeta 1 Quote
manuuuu400 Posted August 24, 2025 Posted August 24, 2025 Great. Tested it, works as expected. Thanks for the very quick response Quote
Fiery Posted August 25, 2025 Posted August 25, 2025 20 hours ago, manuuuu400 said: Great. Tested it, works as expected. Thanks for the very quick response Thank you for your feedback! Quote
