bondisdead Posted Tuesday at 01:08 AM Posted Tuesday at 01:08 AM Have a new Ryzen 9 9950X3D on a MSI X870E TOMAHAWK WIFI motherboard and T-Create 96GB 6000MHz CL38 DDR5 RAM. I want to run stability test, as I have an advanced PBO setting to maintain 85C. I launch Stability Test with the defaults to stress CPU, FPU, cache and system memory. I have verified in Preferences to use 95% of RAM. I Start it test, and it will run on 30 of the 32-threads. Meanwhile, it will only use 8GB of the 92GB of RAM. I wait 45-min, and still the same. Meanwhile, I try the same test on a system with a Ryzen 9 9900X and 32GB RAM, and all 24-threads and 95% of RAM is used. Is it an issue with the 92GB RAM or the new CPU Quote
Fiery Posted Tuesday at 02:21 PM Posted Tuesday at 02:21 PM 13 hours ago, bondisdead said: Have a new Ryzen 9 9950X3D on a MSI X870E TOMAHAWK WIFI motherboard and T-Create 96GB 6000MHz CL38 DDR5 RAM. I want to run stability test, as I have an advanced PBO setting to maintain 85C. I launch Stability Test with the defaults to stress CPU, FPU, cache and system memory. I have verified in Preferences to use 95% of RAM. I Start it test, and it will run on 30 of the 32-threads. Meanwhile, it will only use 8GB of the 92GB of RAM. I wait 45-min, and still the same. Meanwhile, I try the same test on a system with a Ryzen 9 9900X and 32GB RAM, and all 24-threads and 95% of RAM is used. Is it an issue with the 92GB RAM or the new CPU In AIDA64 please press Ctrl+D --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
bondisdead Posted Tuesday at 02:37 PM Author Posted Tuesday at 02:37 PM Thanks for the reply! Here is what you are asking for. cpuidmsrdump.txt Quote
Fiery Posted Tuesday at 09:38 PM Posted Tuesday at 09:38 PM 7 hours ago, bondisdead said: Thanks for the reply! Here is what you are asking for. cpuidmsrdump.txt 218.4 kB · 2 downloads Thank you! We've tested it on a 9950X3D based system with 48GB RAM, and AIDA64 managed to push all 32 CPU threads to 100% and allocated 46.0GB RAM. So I suppose something must be peculiar in your system that caused that issue. Maybe try to restart Windows and try it again, that alone may just help. Quote
bondisdead Posted Wednesday at 12:44 AM Author Posted Wednesday at 12:44 AM Yeah, strange then. I tried both 64gb and 32gb of RAM, and it barely used any ram. Also the same slow ramp-up to using most, but not all of the cores. All settings in BIOS are at their defaults, or with EXPO, made no difference. I have used this motherboard and others, and always maxed out ram testing before, albeit with the different CPU. I can run Prime95 and IntelBurnTest, and all 96GB of RAM is used. As an aside, is aida64 stability test able to stress RTX 5000 GPUs? It only utilizes the AMD iGPU. This used to work when I was using RTX 4000 GPUs. Quote
Fiery Posted Wednesday at 09:41 AM Posted Wednesday at 09:41 AM 8 hours ago, bondisdead said: As an aside, is aida64 stability test able to stress RTX 5000 GPUs? It only utilizes the AMD iGPU. This used to work when I was using RTX 4000 GPUs. No, that is not supported yet, and is due to the fact that nVIDIA decided to remove the 32-bit OpenCL layer from their drivers on RTX 5000 GPUs. Quote
