Calmills Posted January 5, 2011 Posted January 5, 2011 I just purchased the AIDA64 Business Edition and the Remote Control Function Does Not Work. When I Launch The App The Display Is Blank. I Have Also Install The Application On The Remote Computer. I Have Sent Both To Accept Incoming Connections. Can Any On Help Me With This Problem? GM Quote
Mice007 Posted January 5, 2011 Posted January 5, 2011 Are the other AIDA64 remote features working good? What is the version of Windows you using (both server and client side)? I just purchased the AIDA64 Business Edition and the Remote Control Function Does Not Work. When I Launch The App The Display Is Blank. I Have Also Install The Application On The Remote Computer. I Have Sent Both To Accept Incoming Connections. Can Any On Help Me With This Problem? GM Quote
Calmills Posted January 5, 2011 Author Posted January 5, 2011 The Server is Windows 2003 and my desktop is Windows 7 Enterprise. This issue occurs on both sides. Quote
Calmills Posted January 5, 2011 Author Posted January 5, 2011 Let me clarify the problem. The only issue is the graphical portion of the control. All other functions are ok. Only when I use the graphical portion of the application is where I have the problems. Its seems to be connected, but there is now display of the controlled computer screen. Quote
Mice007 Posted January 5, 2011 Posted January 5, 2011 Okay thanks for the answers... One more, how do you start AIDA64 on the server side? Let me clarify the problem. The only issue is the graphical portion of the control. All other functions are ok. Only when I use the graphical portion of the application is where I have the problems. Its seems to be connected, but there is now display of the controlled computer screen. Quote
Calmills Posted January 5, 2011 Author Posted January 5, 2011 I use the command line aida64 /acceptmin /silent in the startup. Quote
