FatBoyNL Posted April 5, 2025 Posted April 5, 2025 The SSD Physical Info provided under Storage > ATA seems to be incorrect for my Samsung SSD 990 PRO 4TB. The 4TB version is being manufactured in a newer revision than the first generation of 1-2 TB 990 PRO drives, which were produced using 176-layer TLC NAND flash. But the 4TB version and the newer 1-2 TB revision both seem to be using a 236-layer TLC NAND flash, please see: https://www.techpowerup.com/ssd-specs/samsung-990-pro-4-tb.d863 Could you please update the specs for the 4TB version in the hardware database? Thanks! Quote
Fiery Posted April 5, 2025 Posted April 5, 2025 6 hours ago, FatBoyNL said: The SSD Physical Info provided under Storage > ATA seems to be incorrect for my Samsung SSD 990 PRO 4TB. The 4TB version is being manufactured in a newer revision than the first generation of 1-2 TB 990 PRO drives, which were produced using 176-layer TLC NAND flash. But the 4TB version and the newer 1-2 TB revision both seem to be using a 236-layer TLC NAND flash, please see: https://www.techpowerup.com/ssd-specs/samsung-990-pro-4-tb.d863 Could you please update the specs for the 4TB version in the hardware database? Thanks! Thank you, we'll fix the issue in the next AIDA64 beta update. Quote
FatBoyNL Posted April 8, 2025 Author Posted April 8, 2025 On 4/5/2025 at 9:19 PM, Fiery said: Thank you, we'll fix the issue in the next AIDA64 beta update. Thanks, it's fixed in AIDA64 v7.65.7400 👍 Quote
Fiery Posted April 8, 2025 Posted April 8, 2025 10 minutes ago, FatBoyNL said: Thanks, it's fixed in AIDA64 v7.65.7400 👍 Thank you for your feedback! Quote
