fixed: Blue screen when reporting or viewing PCI device settings Innogrit RainierQX IG5220 PCIe 4.0 x4 NVMe 1.4 (GMKtec NucBox K8 Plus)
Win 11
Computer type  GMKtec NucBox K8 Plus
Disk drive DGSM4001TG23T
PCI Devices:
Bus 5, Device 0, Function 0 Innogrit RainierQX IG5220 PCIe 4.0 x4 NVMe 1.4 4-channel DRAM-less SSD Controller
When viewing information about Innogrit RainierQX IG5220 or receiving a report, it freezes and crashes with a blue screen, after which the disk is inaccessible. It is visible again only after turning off and on the computer. When running under winpe, everything is fine, i.e. the problem occurs only when the disk controller parameters are viewed when the operating system is running from it.
4 hours ago, Galsus said:
Win 11
PCI Devices:
Let me know if it helps.
  • Thanks 1
2 hours ago, Galsus said:
Thank you, the error has been fixed. I couldn't answer before.
Thank you for your feedback!
  • Fiery changed the title to fixed: Blue screen when reporting or viewing PCI device settings Innogrit RainierQX IG5220 PCIe 4.0 x4 NVMe 1.4 (GMKtec NucBox K8 Plus)
