nbtc971 Posted June 6 Posted June 6 Was there a Windows 11 update that has hosed something? It's been working for years now no CPU information and AIDA apparently can't detect sensor info? What I mean to say is, I don't believe stats are being sent over to the registry because Goverlay isn't getting the CPU information. AIDA64, when I try to investigate what might be happening, just says it's detecting sensor information and seems to go on and on... Quote
Fiery Posted June 6 Posted June 6 12 hours ago, nbtc971 said: Was there a Windows 11 update that has hosed something? It's been working for years now no CPU information and AIDA apparently can't detect sensor info? What I mean to say is, I don't believe stats are being sent over to the registry because Goverlay isn't getting the CPU information. AIDA64, when I try to investigate what might be happening, just says it's detecting sensor information and seems to go on and on... Have you tried it with the latest AIDA64 beta update? Quote
nbtc971 Posted June 8 Author Posted June 8 I'll give it a shot and let you know. Nah, didn't work: I'll keep fooling with it and see if I can solve it. Quote
nbtc971 Posted June 8 Author Posted June 8 I give up. It's just not doing what it used to do. I had just purchased a 2 year license because my key had expired. Having to request a refund. Not sure what broke it after several years, but that's where we're at. Quote
Fiery Posted June 8 Posted June 8 4 hours ago, nbtc971 said: I give up. It's just not doing what it used to do. I had just purchased a 2 year license because my key had expired. Having to request a refund. Not sure what broke it after several years, but that's where we're at. Do you have any external devices that you recently connected? Mainly any USB devices? Quote
nbtc971 Posted June 9 Author Posted June 9 No. Ok.. now it just started working? I haven't even been messing with it today. I had it turned off. Then my system crashed while playing a game, and it came up on restart. I looked at it, and it's working. I don't know what's going on, but I guess I'm good, for the time being. Quote
Fiery Posted June 10 Posted June 10 23 hours ago, nbtc971 said: No. Ok.. now it just started working? I haven't even been messing with it today. I had it turned off. Then my system crashed while playing a game, and it came up on restart. I looked at it, and it's working. I don't know what's going on, but I guess I'm good, for the time being. Perhaps that unusual way of restarting Windows put things back in order Quote
