Antiram Posted June 11, 2025 Posted June 11, 2025 Hello I use a Ryzon AI 9 HX 370 based Mini PC. It is the Minisforum AI X1 Pro with an AMI Bios The PC does not recognize a CPU fan or a case fan with myfull version of AIDA64 7.99 7809beta. There is no option to choose a CPU fan or a case fan with my machine. All other stuff is working fine. I used the latest Beta because I own a Turzx 5 " display Is it possible to add those fans ? Regards David https://minisforumpc.eu/products/ai-x1-pro-mini-pc? ecdump.txt isasensordump.txt Quote
Fiery Posted June 11, 2025 Posted June 11, 2025 1 hour ago, Antiram said: Hello I use a Ryzon AI 9 HX 370 based Mini PC. It is the Minisforum AI X1 Pro with an AMI Bios The PC does not recognize a CPU fan or a case fan with myfull version of AIDA64 7.99 7809beta. There is no option to choose a CPU fan or a case fan with my machine. All other stuff is working fine. I used the latest Beta because I own a Turzx 5 " display Is it possible to add those fans ? Regards David In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Also in AIDA64 please press Ctrl+D --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Antiram Posted June 11, 2025 Author Posted June 11, 2025 6 hours ago, Fiery said: In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Also in AIDA64 please press Ctrl+D --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Thank you. Here it is. ecdump.txt isasensordump.txt Quote
Fiery Posted June 12, 2025 Posted June 12, 2025 On 6/11/2025 at 4:40 PM, Antiram said: Thank you. Here it is. ecdump.txt 2.19 kB · 1 download isasensordump.txt 8.56 kB · 1 download Thank you! I'm afraid we cannot find the relevant registers that could be used to measure fan RPM on your system We'd need help from the manufacturer of the device, Minisforum to solve this issue. Quote
Antiram Posted June 12, 2025 Author Posted June 12, 2025 Ok thanks. I send an Email to the Minisforum support. Hope they will help. Quote
Antiram Posted June 13, 2025 Author Posted June 13, 2025 Looks like Minisforum support will not help. They wrote: "Dear customer It seems that no option can achieve this. Best regards, Mike MINISFORUM SUPPORT" That´s sad. Any other idea ? I could do a logfile again with different fan speeds doing full CPU load or nothing. Would that help ? Regards Quote
Fiery Posted June 13, 2025 Posted June 13, 2025 1 hour ago, Antiram said: Looks like Minisforum support will not help. They wrote: "Dear customer It seems that no option can achieve this. Best regards, Mike MINISFORUM SUPPORT" That´s sad. Any other idea ? I could do a logfile again with different fan speeds doing full CPU load or nothing. Would that help ? Regards That's a pity I'm afraid we're stuck since we're 99% sure the method would involve writing a value to one of the Embedded Controller (EC) registers and then read the fan RPM value from another register. But without knowing the register indexes and values, it's a huge number of combination that we'd have to try. And brute-force trying to write to EC would also risk damaging the hardware too, so it's a no-go Quote
