cpachris Posted February 10, 2014 Posted February 10, 2014 It doesn't happen all the time, and sometimes rebooting the computer will solve it, but it always seems to happen again at some point. The only two sensor readings I've seen it happen to our the 'Motherboard' and the 'CPU'. It reports this even when the computer is idling and cool. I have a Asrock Extreme 11. It used to work properly all the time. No BIOS upgrades recently to blame. Help? Quote
Fiery Posted February 10, 2014 Posted February 10, 2014 1) Do you have any other sensor monitoring, tweaking or overclocking software installed? Either made by ASRock or a 3rd party? 2) Does your motherboard use a X79, Z77 or Z87 chipset? Quote
cpachris Posted February 10, 2014 Author Posted February 10, 2014 1) Do you have any other sensor monitoring, tweaking or overclocking software installed? Either made by ASRock or a 3rd party? 2) Does your motherboard use a X79, Z77 or Z87 chipset? 1) there is some asrock software, but i don't even have it loading...and i'm still getting the false temps anyway. 2) X79 Quote
Fiery Posted February 11, 2014 Posted February 11, 2014 Can you please try to uninstall the mentioned ASRock software and see if it makes a difference? That software may have a background process or service that is still running, even when you opted for the application to not be auto-launched at Windows bootup. Also, make sure to use the latest AIDA64 Extreme beta release available at: http://www.aida64.com/downloads/aida64extremebuild2770x1wr9gzpktzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Quote
cpachris Posted February 13, 2014 Author Posted February 13, 2014 I'm running the latest AIDA....there are no services related to the Asrock software running unless it is started....and the Asrock software has been on my machine for a year. The problem with AIDA is new. Just to be sure, I uninstalled the Asrock software, and experienced the same error with AIDA. Quote
Fiery Posted February 20, 2014 Posted February 20, 2014 Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild2808b9s8mvtkpqzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. If not, then please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Quote
cpachris Posted February 21, 2014 Author Posted February 21, 2014 Hmmmm.....gone for now. I'll repost if it surfaces again. Quote
