Anthony Siti Posted July 11 Posted July 11 I'm trying to set up remote monitoring between my main gaming rig and a mini PC using the business version of the software. I can't seem to get the connection to work. I've tried port forwarding on my router and creating firewall exceptions on both PCs, but I consistently get a "connection refused" error. Do you have any insights or ideas that might help me troubleshoot this issue? @Fiery Quote
Fiery Posted July 12 Posted July 12 8 hours ago, Anthony Siti said: I'm trying to set up remote monitoring between my main gaming rig and a mini PC using the business version of the software. I can't seem to get the connection to work. I've tried port forwarding on my router and creating firewall exceptions on both PCs, but I consistently get a "connection refused" error. Do you have any insights or ideas that might help me troubleshoot this issue? @Fiery Have you enabled incoming connections on your main rig using Remote / Accept Incoming Remote Connections ? Quote
Anthony Siti Posted July 13 Author Posted July 13 How would I do that? Is something I need to change in the firewall settings? Quote
Fiery Posted July 14 Posted July 14 8 hours ago, Anthony Siti said: How would I do that? Is something I need to change in the firewall settings? It's in AIDA64 / kebab (3 dots) menu. Quote
Anthony Siti Posted July 14 Author Posted July 14 Thank you — I was able to find and enable the feature. However, I’ve run into another issue that I’m hoping you might be able to help with. I recently purchased a sensor panel from a creator I found through the forums, and I’m trying to display it on a separate mini PC with a small screen. My goal is to have the data from my main rig displayed remotely on the mini PC using the sensor panel feature in the software. I’d prefer not to use the LCD function or rely on a simple webpage. If that's the only option, is there any way to convert an existing sensor panel into the appropriate format for remote display? Quote
Fiery Posted July 15 Posted July 15 11 hours ago, Anthony Siti said: Thank you — I was able to find and enable the feature. However, I’ve run into another issue that I’m hoping you might be able to help with. I recently purchased a sensor panel from a creator I found through the forums, and I’m trying to display it on a separate mini PC with a small screen. My goal is to have the data from my main rig displayed remotely on the mini PC using the sensor panel feature in the software. I’d prefer not to use the LCD function or rely on a simple webpage. If that's the only option, is there any way to convert an existing sensor panel into the appropriate format for remote display? I'm afraid you cannot transfer your system data and sensor measurements that way from one PC to another. If you mean to transfer your SensorPanel layout from one PC to another, then you can export your layout using the Export button on the SensorPanel Manager. Quote
