Fiery Posted September 7, 2025 Posted September 7, 2025 On 9/5/2025 at 10:21 AM, Winterfoot said: also kinda interesting, the flow correction disappeared after I set it back to one. I can't put it back Please check this issue as well with the beta I've linked above. Quote
Winterfoot Posted September 8, 2025 Author Posted September 8, 2025 I'll do a deeper dive tomorrow, BUT it appears to be working perfectly now. Base pump speeds (30%) gives a N/A value (minimum detectable rate likely), but once I increase the speed it reports values that seem reasonable for what it is. 35-40% is around 20-30LPH, 100% speed lands around 150LPH. Quote
Winterfoot Posted September 8, 2025 Author Posted September 8, 2025 On 9/7/2025 at 5:54 AM, Fiery said: Please check this issue as well with the beta I've linked above. flow correction is still not on the available list. sorry missed this thread has a second page Quote
Fiery Posted September 14, 2025 Posted September 14, 2025 On 9/8/2025 at 5:48 PM, Winterfoot said: flow correction is still not on the available list. sorry missed this thread has a second page Thank you for your feedback. We've checked and unless flow rate is reported as zero, it should appear in the list of available items for correction. It's puzzling if it indeed doesn't appear for you. Quote
Winterfoot Posted September 15, 2025 Author Posted September 15, 2025 I went back to double check and it is there now and modifiable... no idea why it wasn't there before. Quote
Fiery Posted September 15, 2025 Posted September 15, 2025 8 minutes ago, Winterfoot said: I went back to double check and it is there now and modifiable... no idea why it wasn't there before. No worries, I'm glad it works now. The item could be removed from the list in case by the time the polling of sensor items happens the sensor reports an invalid value (momentarily). Quote
Winterfoot Posted September 15, 2025 Author Posted September 15, 2025 you know, that actually makes some sense. before I optimized fan control, i would get an N/A value purely based on sensor limitations and the pump running below the detectable limit. If i was looking for the flow correction then it wouldn't be findable. I've since optimized the fan control so it reports at least the lowest detectable limit, hence it shows back up. Quote
