zaheerjane Posted July 29 Posted July 29 hi guys i have 2 8.8 usb monitors • one is truzx which works fine when plugged in • the second one is non branded and when plugged in starts a blur amd logo and then only a white screen • i tried with external usb c cable and motherboard usb to usb c still same issue • also the lcd works fine with truzx controller i tried the lcd selection options in the preferences tab but can not figure out which one will work. the panel info is in pics thanks Quote
Fiery Posted July 31 Posted July 31 On 7/29/2025 at 5:46 PM, zaheerjane said: hi guys i have 2 8.8 usb monitors • one is truzx which works fine when plugged in • the second one is non branded and when plugged in starts a blur amd logo and then only a white screen • i tried with external usb c cable and motherboard usb to usb c still same issue • also the lcd works fine with truzx controller i tried the lcd selection options in the preferences tab but can not figure out which one will work. the panel info is in pics thanks Please disconnect the Turzx device (the one that works fine) from your PC. Connect the second, non-branded device to your PC (the one that doesn't work). In AIDA64 please press Ctrl+D --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
