jbawz Posted September 21, 2025 Posted September 21, 2025 Hey everyone, First time poster here. I made some basic sensor panel to test the waters. Is there a way to make my panel display when the computer is powered on? Currently, when the display turns on, it is the Turzx display and panel. I have to shutdown the service from the system tray, and then launch Aida64 to see my custom panel. Is there a way to see my custom panel off the start? What settings do I need to change? I tried setting Aida64 to launch at startup, which it does, but it does not override the Turzx.exe startup application. When I close Turzx.exe, the entire display powers off - so I think I need to have it running. Thanks so much! Quote
Loyd Posted September 28, 2025 Posted September 28, 2025 the turzx.exe does not need to run. I am running 4 3.5inch displays all plugged into an usb strip. they look dead until AIdia64 comes up and loads the required files. try it, you will like it Quote
