SoloSK71 Posted September 29, 2025 Posted September 29, 2025 I have a panel that worked fine on my 1024x768 3rd monitor, but since the upgrade to version 8 will not scale properly. If I move it to one of my main screens it does scale properly but increases in size to what looks like 1280x based. Quote
Fiery Posted September 29, 2025 Posted September 29, 2025 40 minutes ago, SoloSK71 said: I have a panel that worked fine on my 1024x768 3rd monitor, but since the upgrade to version 8 will not scale properly. If I move it to one of my main screens it does scale properly but increases in size to what looks like 1280x based. AIDA64 v8.00 will adapt to the actual DPI (zoom) setting of each monitor in your system. In order to make a layout suitable for both 100% DPI and high-DPI monitors, you need to use high-DPI images on your layout (ie. higher resolution than what you'd require on your 1024x768 3rd monitor) and use the resizing option to scale them down to the necessary resolution. Quote
