SickVillain Posted October 1 Posted October 1 I want to scale the entire template (all items) down proportionally so it fits my monitor without manually moving or resizing each element, avoiding overlapping or messy layout. Specifically, I want to: Scale the entire 1920×480 template to 1480×320 in bulk Keep all elements proportional and visible Save the panel so the floating panel displays correctly on my monitor I would greatly appreciate detailed instructions or a video/resource that clearly explains how to do this in the current version of AIDA64 Quote
Fiery Posted October 1 Posted October 1 24 minutes ago, SickVillain said: I want to scale the entire template (all items) down proportionally so it fits my monitor without manually moving or resizing each element, avoiding overlapping or messy layout. Specifically, I want to: Scale the entire 1920×480 template to 1480×320 in bulk Keep all elements proportional and visible Save the panel so the floating panel displays correctly on my monitor I would greatly appreciate detailed instructions or a video/resource that clearly explains how to do this in the current version of AIDA64 There's no automatic method to do that with absolute precision. But, in case you'd find it useful to scale everything down by 75% (which is close to what you're looking for IMHO), you can try to download the latest AIDA64 beta update: https://www.aida64.com/downloads/latesta64xebeta On the SensorPanel right-click --> Scale --> Scale all items down by 75%. Make sure to backup your SensorPanel layout before trying that out. 1 Quote
SickVillain Posted October 1 Author Posted October 1 Thank you for your suggestion. I did exactly what you recommended — after and before resizing the background and using the “scale all items down” option, the panel did scale, However, there are still some (if not quite a lot) of resizing and aligning required. That said, I honestly don’t mind it. For me, it’s actually enjoyable to manually align and fine-tune everything, since I want the panel to look exactly the same as the larger template. My question is: how do the template creators manage to set and align/resize everything so perfectly in the first place? Is there a method or tool they use that makes it easier? Quote
Fiery Posted October 2 Posted October 2 23 hours ago, SickVillain said: My question is: how do the template creators manage to set and align/resize everything so perfectly in the first place? Is there a method or tool they use that makes it easier? They either have a specific method in place to do that or they just fiddle around with each layout a lot 🙂 1 Quote
