Sas27 Posted November 21 Posted November 21 Hi, I just wonder why AIDA does not show the temperature of SSD Controller? It shows only temperatures of memory chip and/or SSD PCB. On the other side, the controller temperature is normally a bit higher than memory module. Is that a possibility of future upgrade in new releases? Quote
Fiery Posted November 21 Posted November 21 13 minutes ago, Sas27 said: Hi, I just wonder why AIDA does not show the temperature of SSD Controller? It shows only temperatures of memory chip and/or SSD PCB. On the other side, the controller temperature is normally a bit higher than memory module. Is that a possibility of future upgrade in new releases? Most SSDs do not measure controller temperature. Can you see the missing thermal reading using other tools like HD Sentinel or CrystalDiskInfo? Quote
Sas27 Posted November 21 Author Posted November 21 Yes, I have seen Controller temperatures on two SSDs: Samsung 990 Evo Plus and Silicon Power US75 using HWInfo tool. It shows three temperatures, instead of two ones in AIDA. I've monitored temperatures during CrystalDiskTest with both tools. AIDA showed only two the same temeratures while HWInfo showed three, one of which was much higher than two others. Especially Samsung, which is much "hotter" than SPCC. Obviously this is Controller temperature. Quote
Fiery Posted November 21 Posted November 21 5 minutes ago, Sas27 said: Yes, I have seen Controller temperatures on two SSDs: Samsung 990 Evo Plus and Silicon Power US75 using HWInfo tool. It shows three temperatures, instead of two ones in AIDA. I've monitored temperatures during CrystalDiskTest with both tools. AIDA showed only two the same temeratures while HWInfo showed three, one of which was much higher than two others. Especially Samsung, which is much "hotter" than SPCC. Obviously this is Controller temperature. Please post a screenshot of the 3 SSD temperatures as reported by HWiNFO. Thank you! Quote
Fiery Posted November 23 Posted November 23 AIDA64 doesn't show all 3 temperatures because -- as you can see -- two of them indicate the same reading all the time. So AIDA64 would pick the 2 temperatures out of the 3 that are not identical. Quote
Sas27 Posted December 4 Author Posted December 4 There is a good reason for program upgrade in the next releases, isn't it? Quote
