ezfofo83 Posted November 21, 2025 Posted November 21, 2025 Hello, it is known that the gpu power percent monitoring sensor in any app is heavy and lower fps and can stutter, in msi afterburner we can just untick what we dont want (gpu power percent) but in aida64 we can only toggle on or off "gpu sensor support", is there a way to disable sensor individually inside it ? like i want to keep gpu temperature only and disable all the rest ? thank you Quote
Fiery Posted November 23, 2025 Posted November 23, 2025 On 11/21/2025 at 10:34 PM, ezfofo83 said: Hello, it is known that the gpu power percent monitoring sensor in any app is heavy and lower fps and can stutter, in msi afterburner we can just untick what we dont want (gpu power percent) but in aida64 we can only toggle on or off "gpu sensor support", is there a way to disable sensor individually inside it ? like i want to keep gpu temperature only and disable all the rest ? thank you Is it only the GPU TDP% item that could cause stuttering? It's not possible to cherry-pick from sensor items, but in case there's only a single item that could cause headaches, we can add a new option to the Preferences / Stability page to mitigate the issue. Quote
ezfofo83 Posted November 23, 2025 Author Posted November 23, 2025 4 hours ago, Fiery said: Is it only the GPU TDP% item that could cause stuttering? It's not possible to cherry-pick from sensor items, but in case there's only a single item that could cause headaches, we can add a new option to the Preferences / Stability page to mitigate the issue. It is GPU tdp % the heaviest sensor yes but sometimes the GPU W one spikes up too, you can Google "GPU power monitoring stutter" and find threads about it , some say % is enough to disable, some say both percent and W should be disabled. Quote
ezfofo83 Posted November 28, 2025 Author Posted November 28, 2025 On 11/23/2025 at 12:51 PM, Fiery said: Is it only the GPU TDP% item that could cause stuttering? It's not possible to cherry-pick from sensor items, but in case there's only a single item that could cause headaches, we can add a new option to the Preferences / Stability page to mitigate the issue. i can confirm that only the GPU TDP% is the problem, so yes adding a new option in stability page would resolve it 👍 1 Quote
gorwynt Posted December 7, 2025 Posted December 7, 2025 It would be really good for us to offer such an option (disable GPU, CPU TDP and TDP % sensors) , because while AIDA64 is running, this sensor causes a 1% and average FPS drop. Quote
