PixelSlayer404 aka Z Posted November 22, 2025 Posted November 22, 2025 Hi There, I just started using Sensor Panel but it seems to be very laggy while gaming, sometimes it's frozen for 10-15 seconds until it updates. I've tried many "fixes" but nothing helps. Can someone help me? I was so happy that finally I was able to create a panel where I can see everything! But it started lagging like crazy. https://ibb.co/prkpYJrk --> my Sensor Panel https://drive.google.com/file/d/1VthymFl1JetKTguDyO3iVxkLTkup6_0w/view?usp=sharing --> my sensorprof.txt (Sensor Profiling Dump) Thanks in advance! Best Regards, Z Quote
Fiery Posted November 23, 2025 Posted November 23, 2025 On 11/22/2025 at 1:13 AM, PixelSlayer404 aka Z said: Hi There, I just started using Sensor Panel but it seems to be very laggy while gaming, sometimes it's frozen for 10-15 seconds until it updates. I've tried many "fixes" but nothing helps. Can someone help me? I was so happy that finally I was able to create a panel where I can see everything! But it started lagging like crazy. https://ibb.co/prkpYJrk --> my Sensor Panel https://drive.google.com/file/d/1VthymFl1JetKTguDyO3iVxkLTkup6_0w/view?usp=sharing --> my sensorprof.txt (Sensor Profiling Dump) Thanks in advance! Best Regards, Z Can you please repeat the Sensor Profiling Dump when the lagging occurs? For example, when it stalls for 10+ seconds? Also, on what screen do you display your SensorPanel on? Is it a regular monitor connected with DSub, DVI, HDMI or DisplayPort? Or is it a USB-connected external display that doesn't appear as a secondary or tertiary monitor under Windows? Quote
Bearlee Posted December 9, 2025 Posted December 9, 2025 Did you ever find a solution to this? I moved my internals to a new case and upgraded my boot drive from a Samsung 970 Pro to a 990 Pro about 10 days ago. Everything else is same hardware, with a fresh install of windows and Aida64. Now my sensor panel is behaving just like yours. I reached out to support and they had me disable my GPU sensor support, which made it worse and disabled GPU monitoring on panel. I reported findings back and haven't received a reply in 7 days now. I also told them that I found a way to get reporting to work like normal but it will reset with a computer restart. If I open task manager>details>aida64>set priority> realtime, it works like normal in gaming. You're welcome to try it out, if you haven't found a solution. I've been using aida64 for many years and never had this problem. I've had my panel setup on 10" raspberry pi (1024x600) display. Using USB power and full size HDMI port. Let me know if you found a solution or if switching to realtime works for you. I'd like to send another reply back to support referencing this page. Quote
