🚀 Introducing SynQPanel - A New Panel-Based Visualization Tool for AIDA64 Users
@Surjeet @BHSY @Loyd
Hello Everyone,
I’m beyond excited to share that FlipClock is evolving beautifully - and it’s getting better every single day! 🚀
We’ve been working with passion to make it smoother, smarter, and more powerful than ever before. Here’s what’s coming next and currently being tested:
Full Flip Animation - now fully possible and more satisfying than ever.
Flexible Display Options - choose between full digits or single-digit flip style.
Effortless Setup - just provide the numbers 0-9 for single-digit mode, and let SynQPanel handle the magic for you.
Complete Customization Control - fine-tune spacing, adjust flip duration, add dynamic shadows, and even enhance it with stunning 3D lighting effects:
Every detail has been crafted to bring your displays to life with energy and elegance.
Now, get ready to see the magic in motion - Below are both styles in action:
Which one did you like? :)
  • Like 2
Hello Everyone,
I prefer the one on the right; it feels more like a true flip mechanism. 👍
  • Thanks 1
Hi everyone (Thank you @BHSY),
I’d like to share something recently discovered while troubleshooting a system issue.
The Primary IP Address and External IP Address sensors appeared to cause instability with shared memory for most of the users. After disabling/unchecking these two sensors in the shared memory settings, everything returned to normal and the sensor statistics began responding correctly again.
This may not affect most users, but  it might be worth temporarily unchecking these two sensors to see if it helps.
Just sharing this in case it saves someone some troubleshooting time. 🙂
Updated my Realtek network adapter yesterday. Now, the Primary IP Address and External IP Address no longer cause the issue. It all started with the Windows latest update. Anyone facing this issue, please update your Network adapter to the latest driver version.
  • Thanks 1
Dear bro,
Thank you very much for bring us such an amazing app like this. I like some animation in the sensor panel but Aida64 do not have it while others do have (Turzx, Trofeo Vision, etc,...). Therefore this app is a savior. Very great app.
At this moment, I have some issue with it. When I insert a video in the panel, it will flicker randomly. The larger the video, the more often it will happen. Do you have any solution? Or does it have the limitation such as the maximum resolution or bit rate?
  • Like 3
  • Thanks 1
17 hours ago, moonsalini said:
Dear bro,
Thank you so much for your kind words and support - it truly means a lot. I’m really glad the animated sensor panel adds value for you. Especially when you mention it as a “savior” - genuinely motivates us to keep improving every day. Your support is deeply appreciated. 🙏
Regarding the video flickering: this is usually related to performance limits rather than a strict resolution or bitrate cap. Larger videos (higher resolution/bitrate) naturally consume more GPU/CPU resources, which can cause random flickering.
You may try the following steps:
  1. Please check Settings > Performance > Target Frame Rate and try increasing it to see if it improves the smoothness.
  2. Consider slightly reducing the video resolution or bitrate and test again.
  3. Keep in mind that each screen has its own refresh rate and hardware limitations. If the display refresh rate is lower, or if many sensors, images, and animated elements are active simultaneously, it can affect playback smoothness and cause flickering.
In short, the more resources the panel uses (multiple sensors, high-resolution assets, animations, large videos), the heavier the load becomes - and this can sometimes impact video stability.
We are continuously optimizing the app and removing bugs one by one, and feedback like yours helps us improve further.
If possible, please share your panel resolution, display refresh rate, and video specs - I’ll be happy to look into it further. Are you facing such issues with all the panels or specific ones?
After some adjustment and testing. Maybe I know the problems. Its because SynQ uses too much resources for running videos. For example, if I insert 1 video of 480x1280 resolution, 1k bitrates, it will load up to 30-35% CPU usage (Intel 12900HK) and 3-4 core will be push to 100% all the time. While playing such video on Potplayer for example will cause just 5% CPU usage. This is the cause of flickering to happen.
@BHSY @Loyd
Hi Everyone!
I am excited to announce 🎤 that 🎉SynQPanel v1.0.4 is now available.🎉
 ❤️ So many New Things ❤️
Flip Clock Enhancements – Full Flap
(Please note that you one need images 0 to 9 with names 0 to 9 only to have the full new style full flap single digit clock)
Dual Rendering Styles
  • Added Single Digit mode alongside classic Split-Flap
  • Split-Flap: Full-width image sets (00–59) for traditional airport-style displays
  • Single Digit: Independent digit animation using 0–9 assets
Synchronized Digit Logic
  • Tens and ones flip in perfect sync during rollover (e.g., 19 → 20)
  • Preserves realistic mechanical behavior
Visual Improvements
  • 3D lighting and dynamic shading based on flip angle
  • Real-time hinge and ambient depth shadows
  • Smooth ease-in-out animation curves (replaces linear motion)
UI & Customization & Options
  • Live interactive preview
  • Smart auto-sizing for both single- and double-width assets
  • Adjustable animation speed (Minutes / Hours)
  • Shadow intensity and 3D lighting strength controls
  • Redesigned, space-efficient properties panel
Import Validation
  • Automatic image-set validation (0–9 vs 00–59) based on selected mode
  • Prevents incomplete or mismatched configurations
System & Stability Improvements
Core Hardening
  • Improved XML parsing to safely handle malformed or partial config files
  • Hardened shared-memory IPC for improved long-running stability
Export Fix
  • Fixed .sqx export modifying or omitting spzip configuration
Sensor & Weather Fixes
  • CPU Fan: Prevented unexpected source switching
  • Days of the Week: Corrected incorrect day image display
  • 7-Day Forecast: Added extended forecast support
  • Hourly Weather: Added hourly temperature and rain probability
Bug Fixes & Improvements:
  • SynQPanel now waits for AIDA64 if it launches first and auto-connects when AIDA64 starts (no restart required)
  • “Startup Delay” now correctly saves and updates the Windows Logon Task
  • Wattage sensors retain decimal precision after .sqx import
  • Fixed missing hourly weather icons and incorrect time display after re-importing deleted profiles
  • Custom sensor unit spacing now mirrors AIDA64 formatting exactly (°C, °F, %)
  • Fonts without explicit styling now default to Regular/Normal instead of Thin/Hairline
  • TimeFlow absolute sensors now auto zero-pad to two digits (e.g., 05)
📢 Recommended update for all users.
Thank you to the AIDA team and community for feedback, suggestions and logs that helped refine this release. 🙏
The update is available on GitHub here:  ENJOY 🎉
https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.4
Feedback and suggestions are always welcome.   🙏  Thank you again for the support!   🙏
  • Like 2
  • Thanks 1
Thank you!
I will look into it 👍
Hope you are not using or enabled OpenGPL Rendering for the panel.
  • Like 2
2 hours ago, GaHile said:
Thank you!
Yes, I do not enable OpenGL rendering option because everything become smaller when enable it.
Posted (edited)
Thank you, GaHile, and well done for getting the flip‑clock feature working.👍 It's not a fancy design, but I’ve put together a simple 1920x515 flip‑clock with a weather forecast panel for my personal use. Now, I have my fancy system stats sensor panel (2560x720) underneath my monitor and a weather forecast with a flip-clock panel inside my PC case. 💪
Today's weather will be very hot, and the humidity is always high. ☹️
Note: The month, day, and week use normal custom gauge sensors.
Edited by BHSY
  • Thanks 4
Thank you! I will try to reproduce the issue and see if anything can be done here :)
Looking absolutely amazing! The clean panel design and the way SynQPanel has been used really stand out.
We’ll take care of the remaining issues step by step… slowly but surely.
It’s truly encouraging to see the download numbers growing and people being curious enough to try something new. That kind of support means a lot ❤️ 🙏
  • Like 2
  • Thanks 4
Hi!
A wonderful project, remembers  me of the great Infopanel software. I have a massive problem though....if i load a spzip file from aida64, it crashed and there is no restarting possible, it always crashes untill i remove the profiles.xml.
Is there any option to fix that? What do you need?
Best,
Nils
13 minutes ago, Skinny12 said:
Hi!
Best,
Nils
Hey! Just wanted to check - which SynQPanel version are you currently using? 😊
Also, is the issue happening with one specific .spzip file, or are all imports failing for you? And does the .sensorpanel file import fail as well?
It might really help if you try this:
Go to Settings → Enable Diagnostics Mode, then import the problematic .spzip file again. This will generate log files in the logs folder.
Once those logs are created, you can DM them to her so she can take a closer look and figure out what might be going wrong. Hopefully issue could be spotted quickly! 🙂
Hi,
i tested a .sensorpanel file and this one worked.
The log file seems OK.
2026-03-09 16:35:57.451 +01:00 [INF] [19] [.NET TP Worker] - [] Plugin Bluetooth Add-on loaded successfully
2026-03-09 16:35:57.461 +01:00 [INF] [19] [.NET TP Worker] - [] Plugin Display Session loaded successfully
2026-03-09 16:36:03.928 +01:00 [INF] [19] [.NET TP Worker] - [] Plugin Panel Runtime loaded successfully
2026-03-09 16:36:03.932 +01:00 [INF] [19] [.NET TP Worker] - [] Plugin System Pulse loaded successfully
2026-03-09 16:36:03.932 +01:00 [INF] [19] [.NET TP Worker] - [] Plugin TimeFlow loaded successfully
2026-03-09 16:36:03.933 +01:00 [INF] [19] [.NET TP Worker] - [] Plugin Weather loaded successfully
2026-03-09 16:36:03.933 +01:00 [INF] [19] [.NET TP Worker] - [SynQPanel.Monitors.PluginMonitor] Plugins loaded in 6529ms
2026-03-09 16:36:03.946 +01:00 [INF] [1] [] - [] AIDA: LatestSensors updated. Count=183
Best
Nils
  • Thanks 1
18 hours ago, Skinny12 said:
Hi,
Best
Nils
Logs are looking PERFECT! I have shared a DM with you. Please reinstall SynQPanel as it seems something incomplete with the application causing crashing!
  • Like 2
Hi!
i just finished my new sensorpanel and I’m still very happy with the software.
One thing on my wishlist (two actually):
Could you build the option to have vertical bars?
And as i am using an ipad as secondary monitor it sometimes does not render the sensorpanel to the second screen (because it’s switched off or anything) but to the main screen. Even when the second screen comes back it stays there. Only restarting the software solves this problem. Could you implement a hotkey which reloads the software? I built a batch to do that but it’s a bit annoying to use.
thanks!
 Nils
1 hour ago, Skinny12 said:
Hi!
thanks!
 Nils
Thank you so much for your kind and encouraging words! Your support truly means a lot 🙏
Please find the answers to your questions below:
1. Vertical Bars
Yes, vertical bars are available. Simply decrease the width and increase the height, and the bars will automatically adjust to a vertical orientation.
Example:
2. Fix Screen Option
Could you please try enabling the Fix Screen option and let me know if it works on your end? Your feedback will help us confirm everything is functioning as expected.
In addition, I’ll also check whether we can include a reset button (or hotkey) to quickly restore the application to its default state.
Please feel free to reach out if you need any further assistance - we’re always happy to help! 😊
Thank you!
  • Like 3
  • Thanks 1
1. Vertical Bars
Example:
Thank you!
Wonderful, your advice seems to work fine! Thanks a lot!
//Nils
  • Thanks 1
After Flip Clock, I am excited to share something experimental:
The "Butter" Glide Dynamics approach: Add buttery gauge physics (removes crossfade ghosting) to your custom gauges and they will feel sliding. Please see and share your thoughts if you feel any difference:
 ❤️ This lovely panel was shared by @BHSY 😍
@Loyd I have now fixed the issue where new sensors/items were added to the bottom of the list and changing there position up was not getting saved.
  • Like 4
  • Thanks 1
Oh Wow! 😍 This Butter Glide Dynamics is a huge game-changer. I love it. Awaiting for your next update.
  • Like 2
  • Thanks 1
