G33zzer Posted January 4 Posted January 4 Morning all, I'm surprised to find that there has been no mention of the new Lian Li 8.8 screen yet! (well, that's what the search bar is telling me) Anyways, I love the Aida64 Extreme product, I have used it on a previous BeadaPanel 6P screen and found it nice and easy to use. As you probably know, Lian Li released an 8.8" screen which I had to have 2 of. I have now mounted them and they work great, however the templates and sensors are very limited. Does Aida64 support this panel (not as a secondary screen, through USB)? If so, could someone please assist on how to get Aida64 working on these panels please? Thanks Quote
Fiery Posted January 18 Posted January 18 On 1/4/2026 at 1:33 AM, G33zzer said: Morning all, I'm surprised to find that there has been no mention of the new Lian Li 8.8 screen yet! (well, that's what the search bar is telling me) Anyways, I love the Aida64 Extreme product, I have used it on a previous BeadaPanel 6P screen and found it nice and easy to use. As you probably know, Lian Li released an 8.8" screen which I had to have 2 of. I have now mounted them and they work great, however the templates and sensors are very limited. Does Aida64 support this panel (not as a secondary screen, through USB)? If so, could someone please assist on how to get Aida64 working on these panels please? Thanks That screen in USB mode is not supported by AIDA64 yet. We do have plans to implement support for it later this year though. Quote
ArtTheClown Posted February 1 Posted February 1 d/l l connect beta and there is a driver file, after that use your aida64 themes. you can also just remove the driver files, uninstall l connect and install the drivers if you dont need l connect for anything else Quote
