DarkKnightGamer90 Posted 6 hours ago Posted 6 hours ago i installed the software yesterday after buying a small IPS monitor and everything was working till this morning its stopped working. ive done everything i can think of but nothing is working. can i get some help please Quote
Fiery Posted 6 hours ago Posted 6 hours ago 9 minutes ago, DarkKnightGamer90 said: i installed the software yesterday after buying a small IPS monitor and everything was working till this morning its stopped working. ive done everything i can think of but nothing is working. can i get some help please Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it helps. Quote
DarkKnightGamer90 Posted 4 hours ago Author Posted 4 hours ago 1 hour ago, Fiery said: Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it helps. Hi its stuck on detecting sensor info. thank you Quote
Fiery Posted 4 hours ago Posted 4 hours ago Just now, DarkKnightGamer90 said: Hi its stuck on detecting sensor info. thank you What motherboard and CPU do you have? Quote
DarkKnightGamer90 Posted 4 hours ago Author Posted 4 hours ago AMD Ryzen 7 3800X, 4346 MHz (43.75 x 99) MSI MAG B550 Tomahawk (MS-7C91) (2 PCI-E x1, 2 PCI-E x16, 2 M.2, 4 DDR4 DIMM, Audio, Video, Dual Gigabit LAN) thank you Quote
DarkKnightGamer90 Posted 4 hours ago Author Posted 4 hours ago 14 minutes ago, Fiery said: What motherboard and CPU do you have? does that help? Quote
