khons Posted March 8, 2014 Posted March 8, 2014 hello, in the bios +12v is fine but then in the program shows 9.856v also what mean aux in the temp sensors shows 80c its too much? here my sensor dump, thanks isasensordump.txt Quote
Fiery Posted March 11, 2014 Posted March 11, 2014 Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild2827jfg9rmvxdwzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps.Thanks, Fiery Quote
khons Posted March 12, 2014 Author Posted March 12, 2014 Ok, now no more aux temp and +12v seems fine but The +5v its a bit low Cpu and motherboard temp sensors are switched? Here pics of bios, the program and another sensor dump, thanks isasensordump2.txt Quote
Fiery Posted March 12, 2014 Posted March 12, 2014 Thank you, the +12V reading will be fixed in the next AIDA64 beta release due next week. Quote
