UserXP Posted March 23, 2014 Posted March 23, 2014 Hi all. I just registered to post a question about the CPU temperature. I have this old Socket478 motherboard GA-8IPE1000-G v4.0 by Gigabyte and a 3.0GHz Northwood based Pentium 4 processor on it. I've made a test, so here is the thing: I had a stock cooler on this processor which kept it around 40 degrees, and this temperature (+/- a degreee or soo) was reported by both AIDA64 and the BIOS. However, I've recently mounted a new Zalman cooler and BIOS now reports temperatures which are lower, barely reaching 30 degrees, which is somewhat expected since the cooler is all copper, much better and larger than the stock one. However, AIDA64 still reports temperatures around 40-45 degrees - it is as if it were fixed on those temps for this CPU model and that's it. If I restart Windows at the moment while AIDA64 reported temps like 45 degrees and immediately enter BIOS, BIOS will show current temp around 26-30 degrees. Why is this happening? BIOS is Award Modular 2005, version F5. CPU is Intel Pentium 4 (200 x 15 = 3GHz), Northwood core, nothing overclocked. Thanks in advance for any clarifications. Quote
Fiery Posted March 28, 2014 Posted March 28, 2014 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic.Thanks, Fiery Quote
UserXP Posted March 28, 2014 Author Posted March 28, 2014 OK, here it is: Motherboard ID : 08/19/2005-i865PE-6A79ZG0SC-00 Motherboard Model : Gigabyte GA-8IPE1000-G v4 Motherboard Chipset : Intel Springdale i865PE Award BIOS Type : Award Modular BIOS v6.00PG Award BIOS Message : Intel 865PE AGPSet BIOS for 8IPE1000-G/L F5 DMI MB Manufacturer : Gigabyte Technology Co., Ltd. DMI MB Product : 8IPE1000-G/L DMI MB Version : DMI MB Serial : DMI SYS Manufacturer: DMI SYS Product : DMI SYS Version : DMI SYS Serial : DMI BIOS Version : F5 ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = FFFFh Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = 6001h ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ Gigabyte EasyTune ]------ T1: 28 C F0: 2409 RPM F2: 0 RPM F4: 1806 RPM V0: 12.020 V V1: 5.040 V V2: 3.380 V V3: 1.600 V Quote
Fiery Posted March 28, 2014 Posted March 28, 2014 Thank you, but I'm afraid that dump didn't include any information for your onboard sensor chip. Are you sure everything was okay with AIDA64 when you made the dump? Or maybe you've stripped some parts of the dump output? Quote
UserXP Posted March 28, 2014 Author Posted March 28, 2014 No, I have used the "Copy to Clipboard" button. I have only omitted the first two lines about AIDA64 version and the operating system. Everything else was inserted here. If this is of any help, in the Sensor window, AIDA64 says this: Sensor Type: SMSC LPC47M192/997 (SMBus 2Dh) Quote
Fiery Posted March 29, 2014 Posted March 29, 2014 Ah, yes, my bad, it's an SMBus based sensor Then please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results here. Thanks, Fiery Quote
UserXP Posted March 29, 2014 Author Posted March 29, 2014 OK, no problem. Thanks for the effort so far. Here is the SMBus Dump (Full) data that you've required: ------[ Motherboard Info ]------ Motherboard ID : 08/19/2005-i865PE-6A79ZG0SC-00 Motherboard Model : Gigabyte GA-8IPE1000-G v4 Motherboard Chipset : Intel Springdale i865PE Award BIOS Type : Award Modular BIOS v6.00PG Award BIOS Message : Intel 865PE AGPSet BIOS for 8IPE1000-G/L F5 DMI MB Manufacturer : Gigabyte Technology Co., Ltd. DMI MB Product : 8IPE1000-G/L DMI MB Version : DMI MB Serial : DMI SYS Manufacturer: DMI SYS Product : DMI SYS Version : DMI SYS Serial : DMI BIOS Version : F5 ------[ GPIO @ isa 1080 ]------ 0000 81 31 E0 1A FF FF 00 00 00 00 00 00 00 00 3F 1B 0010 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 FF 39 00 00 0030 07 00 00 00 00 03 00 00 06 03 03 00 00 00 00 00 ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel ICH SMBus Port : 1400 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D2D ]------ 0000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 81 00 ................ 0020 CB 86 C4 C2 C2 C5 2E 1F FF FF FF FF 00 FF 00 FF ................ 0030 00 FF 00 FF 00 FF 00 7F 80 7F 80 FF FF FF 55 20 ............U 0040 09 00 80 FF FF FF FF 0D FF 80 00 13 00 00 FF 00 ................ 0050 D9 FF 01 FF FF 00 FF BB 7F 81 FF FF FF FF FF FF ............... 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D2D ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF81 FF00 0020 FFCB FF86 FFC4 FFC2 FFC2 FFC5 FF2E FF1F FFFF FFFF FFFF FFFF FF00 FFFF FF00 FFFF 0030 FF00 FFFF FF00 FFFF FF00 FFFF FF00 FF7F FF80 FF7F FF80 FFFF FFFF FFFF FF55 FF20 0040 FF09 FF00 FF80 FFFF FFFF FFFF FFFF FF0D FFFF FF80 FF00 FF03 FF00 FF00 FFFF FF00 0050 FFD9 FFFF FF01 FFFF FFFF FF00 FFFF FFBB FF7F FF81 FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D44 ]------ 0000 00 00 0F 3F 00 00 00 00 00 00 00 00 00 00 00 00 ...?............ 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FF00 FF00 FF0F FF3F FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 ------[ SMBus Device B00-D50 ]------ 0000 80 08 07 0D 0B 02 40 00 04 50 65 00 82 08 00 01 ......@..Pe..... 0010 0E 04 18 01 02 20 C0 60 70 75 75 3C 28 3C 28 80 ..... .`puu<(<(. 0020 60 60 40 40 00 00 00 00 00 37 46 28 28 50 00 00 ``@@.....7F((P.. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 A9 ................ 0040 7F 98 00 00 00 00 00 00 04 4B 00 00 00 00 00 00 ........K...... 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 09 02 6C ...............l 0060 0A E9 0B 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 24 B6 00 49 0A FF FF FF FF FF 12 18 31 FF FF .$..I........1.. 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 39 39 55 35 31 39 33 2D 31 30 30 2E 41 30 30 4C 99U5193-100.A00L ------[ SMBus Device B00-D52 ]------ 0000 80 08 07 0D 0B 02 40 00 04 50 65 00 82 08 00 01 ......@..Pe..... 0010 0E 04 18 01 02 20 C0 60 70 75 75 3C 28 3C 28 80 ..... .`puu<(<(. 0020 60 60 40 40 00 00 00 00 00 37 46 28 28 50 00 00 ``@@.....7F((P.. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 A9 ................ 0040 7F 98 00 00 00 00 00 00 04 4B 00 00 00 00 00 00 ........K...... 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 09 33 6C ..............3l 0060 25 A9 41 00 00 00 00 00 00 00 00 00 00 00 00 00 %.A............. 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 24 B6 00 49 0A FF FF FF FF FF 12 18 31 FF FF .$..I........1.. 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 39 39 55 35 31 39 33 2D 30 39 30 2E 41 30 31 4C 99U5193-090.A01L ------[ Chips Found ]------ B00-D2D: SMSC LPC47M192 B00-D52: uPI uP???? I believe this is the chip in question: Quote
UserXP Posted March 29, 2014 Author Posted March 29, 2014 One more test done today. AIDA64 showed 47°C while the PC was at idle for some time. I then decided to restart the computer and to immediately enter BIOS to see its temperature readings. It showed that CPU temp was around 28-30°C only. This is a huge, like 15°C difference. I opened up the casing and the cooler was barely warm to the touch. So BIOS's reading somehow makes more sence than AIDA's. If the CPU temperature had risen really over 45°C, that would have made the heatsink more hot to the touch, wouldn't you agree? Quote
Fiery Posted March 31, 2014 Posted March 31, 2014 Thank you for the data. I agree with your observation, however, we've checked, and everything seems to be alright with how AIDA64 handles your sensor chip. Please check both Motherboard and CPU temperatures before restarting your PC, then go straight to the BIOS Setup, and check those temperatures there. Let me know if there's any match between those. Please also let me know how many temperature readings you can see in the BIOS Setup. Maybe your motherboard only measures a single temperature, but it's labelled "CPU" in the BIOS Setup and "Motherboard" in AIDA64? Quote
UserXP Posted April 3, 2014 Author Posted April 3, 2014 Thanks for the reply/suggestion, and sorry for the delay from my part. OK, here it is: At this moment, the ambient temperature in the room is around 20°C. AIDA64 reports the CPU temp to be 42°C, and Motherboard temp to be 34°C. I have just restarted the PC and entered BIOS. It shows that the CPU temp is only 28°C (which sounds somehow very likely, because of the Northwood core and a very large all-copper Zalman heatsink with a 92mm fan on it at full speed). BIOS reports only CPU temp reading. AIDA64, however, shows temp readings for Motherboard, CPU, GPU and the hard drive. Quote
Fiery Posted April 4, 2014 Posted April 4, 2014 Thank you. The only idea we've left with is that maybe the BIOS Setup uses an offset on the temperature reading to compensate a weak temperature diode. But the only way to verify that theory would be for you to install Gigabyte EasyTune application (that comes with your motherboard), and check temperatures both at idle and under heavy load, while having the AIDA64 Sensor page and EasyTune temperature monitoring page open side-by-side. If you could do that, then please let us know about your findings. Quote
UserXP Posted April 4, 2014 Author Posted April 4, 2014 EasyTune shows CPU temp to be 31°C, while AIDA64 says it is 48°C at the same time. This was taken when the computer was not under load (only these two applications and Google Chrome were opened at the time). The ET reading matches that of BIOS's, and is very logical since the heatsink is barely mildly warm to the touch (in other words, it is too "cold" for a 48°C temperature). Quote
Fiery Posted April 7, 2014 Posted April 7, 2014 Please try to apply an offset of -17 Celsius on the CPU temperature in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction. Quote
UserXP Posted April 7, 2014 Author Posted April 7, 2014 Done. Now AIDA64 also reports what BIOS and ET report. Now that you have mentioned a "BIOS Offset", I remembered something. When I downloaded the BIOS update for this board from Gigabyte's website, it was version F5. However, I remember that in one of the previous BIOS version descriptions there was something about like "Adjust CPU temperature measurement accuracy for Prescott CPU". Although my CPU is not a Prescott one, could it actually be that the BIOS itself has a "patch" for CPU temp reading in order to display the correct temp and is now doing it for both cores, since SMSC sensor chip might do it wrongly (causing AIDA64 do display these wrong readings)? Quote
Fiery Posted April 7, 2014 Posted April 7, 2014 It's possible, yes. Some Gigabyte motherboards use such offsets for voltages and temperatures, so it's not a very unique feature. Sadly, such quirks are usually not easy to have automatically applied in 3rd party software like AIDA64, so you have to find out the offset and use the Correction feature of AIDA64. Quote
UserXP Posted April 7, 2014 Author Posted April 7, 2014 Well, thanks for the help so far. It actually makes sense if Gigabyte did put this offset, because the CPU's heatsink physically gets barely warm and is not even close to temperatures over 40°C. Maybe they figured that the SMSC chip sends too high a reading and therefore flashed the BIOS with this patch to "correct" the problem. Prescott cores run very hot even at idle, I can't imagine what the sensor chip would send to AIDA64 (probably something over 60°C, which is not very nice to see). Quote
