Hello everyone.
On the ASUS maximus vi formula motherboard, there are two 4 pin fan connectors next to the CPU socket: one CPU_FAN and one CPU_OPT. My BIOS can reads the two fans fine, but AIDA does not display the CPU_OPT (the others fan connectors are fine by the way). I don't have te asus ai suite installed by the way.
Any hint? Thanks.
Try to disable Asus ATKEX sensor support in AIDA64 / main menu / File / Preferences / Stability.  Also, make sure to have no AI Suite residuals on your system.  Even after uninstallation AI Suite leaves behind a few services that are still active and prevents AIDA64 to access sensor devices directly.
Thanks Fiery. Sorry, I am posting my issues all at once, but I just started to discover AIDA this weekend and played with it.
The PC is a new build with a fresh install of win8.1pro on brand new ssd. So the AI suite has never been installed. Will try tonight the ATKEX trick and keep you posted. Thanks.
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump.  Copy-paste the full results into this topic.
If possible, please list the fans you have connected when you made the dump, with their corresponding RPM value as well.  That way we can have a reference list of readings and we can compare them with the sensor registers output.
Isasensordump:
------[ AIDA64 Extreme v4.30.2900 ]------
------[ Microsoft Windows 8.1 Professional 6.3.9600.16452 (64-bit) ]------
Motherboard ID : 63-0100-000001-00101111-041312-Chipset$1AQQW031_BIOS DATE: 01/29/14 09:51:35 VER: 14.02
Motherboard Model : Asus Maximus VI Formula
Motherboard Chipset : Intel Lynx Point Z87, Intel Haswell
DMI MB Product : MAXIMUS VI FORMULA
DMI MB Version : Rev 1.xx
DMI MB Serial : 131219846800176
DMI SYS Manufacturer: ASUS
DMI SYS Product : All Series
DMI SYS Version : System Version
DMI SYS Serial : System Serial Number
DMI BIOS Version : 1402
ITE 87xx Port = 00h
ITE 87xx Device ID = 0000h
ITE 87xx Version = 00h
Winbond SuperIO Port = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0290h
Winbond SuperIO HWMonitor Port/64 = 0A00h
Winbond SuperIO Device ID = C803h
Winbond Sensor ID A3/5C/reg$58 = FF / FF / FF
Fintek SuperIO Port = 00h
Fintek SuperIO Device ID = 0000h
LPC47 SuperIO Device ID = FFFFh
ASpeed SuperIO Port = 00h
------[ NCT6791 ISA Sensor Device at 0A00 ]------
0000 6F 7D CF CF 7F F4 52 D7 D2 81 00 95 52 52 52 00
0010 19 1F 2E 7F 0F 2E 00 29 80 20 20 20 20 30 2E 00
0020 19 00 9E 54 9E 9E 00 00 00 00 00 00 00 00 2B 11
0030 11 11 FF 11 FF 11 FF 11 11 11 03 C9 09 A8 00 00
0040 00 00 00 00 09 4C 00 00 00 00 00 00 9E 54 9E 9E
0050 FF FF 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0070 00 20 00 02 00 FF FF FF FF FF FF FF FF FF FF FF
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10 11 1B 20 52 71
T: 25 31 32 25 30 32
T: 25 31 34 25 32 32
T: 25 31 32 25 30 31
T: 25 31 31 25 30 31
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3010</DATA>
_TZ_.TZ01._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3030</DATA>
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
_SB_.PCI0.LPCB.EC0_.OTPC :
_SB_.PCI0.LPCB.EC0_.VGAT :
_SB_.PCI0.LPCB.EC0_.CHPT :
_SB_.PCI0.LPCB.EC0_.CPUT :
_SB_.PCI0.LPCB.EC0_.SYST :
_SB_.PCI0.LPCB.EC0_.DTS1 :
_SB_.PCI0.LPCB.EC0_.DTS2 :
_SB_.PCI0.LPCB.EC0_.DIMM :
_SB_.PCI0.LPCB.EC0_.FANH :
_SB_.PCI0.LPCB.EC0_.FANL :
_SB_.PCI0.LPCB.EC0_.CUTP :
_SB_.PCI0.LPCB.EC0_.PHTP :
_SB_.PCI0.LPCB.EC0_.DIMT :
_SB_.PCI0.LPCB.EC0_.INLE :
_SB_.PCI0.LPCB.EC0_.PANT :
_SB_.PCI0.LPCB.EC0_.F0RM :
_SB_.PCI0.LPCB.EC0_.F0DT :
_SB_.PCI0.LPCB.EC0_.F1RM :
_SB_.PCI0.LPCB.EC0_.F1DT :
_SB_.SAMB.TMPC :
_SB_.SAMB.TMPH :
_SB_.STR0._TMP :
_SB_.STR1._TMP :
_SB_.STR2._TMP :
_SB_.STR3._TMP :
_SB_.STR4._TMP :
_SB_.STR5._TMP :
_SB_.STR6._TMP :
_SB_.STR7._TMP :
Smbusdump:
------[ GPIO @ isa 1C00 ]------
0000 D3 E1 62 BB D3 6E FF 8E 00 00 00 00 FE 7E BF AE
0010 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
0020 00 00 08 00 00 00 00 00 00 00 00 00 10 60 00 00
0030 CF 00 FF 02 F4 FF 56 1F 07 7F FA BE 00 00 00 00
------[ SMBus #0 ]------
SMBus Type : Intel ICH
SMBus Port : F000
Can Have SPD: Yes
Scan Type : Full
------[ SMBus Device B00-D40 ]------
0000 FF 00 00 03 03 FF 00 1C 7C FF 00 00 03 C0 C0 00 ........|.......
0010 00 02 00 6C FF 00 00 FF 00 01 7D 50 F0 60 44 E1 ...l......}P.`D.
0020 CF FF 30 4E BA 00 00 04 01 10 FF 00 00 00 00 00 ..0N............
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 ................
0050 00 00 00 00 00 00 00 00 C0 02 00 00 C0 02 00 00 ................
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 ................
0000 00FF 0000 0000 0003 0003 00FF 0000 0000 00FC 00FF 0000 0000 0003 00C0 00C0 0000
0010 0000 0002 0000 006C 00FF 0000 0000 00FF 0000 0001 007D 0050 00F0 0060 0044 00E1
0020 00CF 00FF 0030 004E 00BA 0000 0000 0004 0001 0010 00FF 0000 0000 0000 0000 0000
0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000F 0000
0050 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0002 0000 0000 00C0 0002 0000 0000
0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0002
0000 00 00 00 04 00 00 00 00 00 06 41 00 03 09 04 14 ..........A.....
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0000 FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF06 FF41 FF00 FF03 FF09 FF04 FF14
0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
------[ SMBus Device B00-D48 ]------
0000 00 21 E0 FF 00 D4 20 78 3D DF 03 49 F0 00 00 00 .!.... x=..I....
0010 0D 00 03 00 26 21 04 00 00 00 00 00 00 00 00 00 ....&!..........
0020 0D 00 03 00 22 25 04 00 00 00 00 00 00 00 00 00 ...."%..........
0040 00 21 E0 FF 00 D4 20 78 3D DF 03 49 F0 00 00 00 .!.... x=..I....
0050 0D 00 03 00 26 21 04 00 00 00 00 00 00 00 00 00 ....&!..........
0060 0D 00 03 00 22 25 04 00 00 00 00 00 00 00 00 00 ...."%..........
0080 00 21 E0 FF 00 D4 20 78 3D DF 03 49 F0 00 00 00 .!.... x=..I....
0090 0D 00 03 00 26 21 04 00 00 00 00 00 00 00 00 00 ....&!..........
00A0 0D 00 03 00 22 25 04 00 00 00 00 00 00 00 00 00 ...."%..........
00C0 00 21 E0 FF 00 D4 20 78 3D DF 03 49 F0 00 00 00 .!.... x=..I....
00D0 0D 00 03 00 26 21 04 00 00 00 00 00 00 00 00 00 ....&!..........
00E0 0D 00 03 00 22 25 04 00 00 00 00 00 00 00 00 00 ...."%..........
0000 FF00 FF21 FFE0 FFFF FF00 FFD4 FF20 FF78 FF3D FFDF FF03 FF49 FFF0 FF00 FF00 FF00
0010 FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0020 FF0D FF00 FF03 FF00 FF72 FF24 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0040 FF00 FF21 FFE0 FFFF FF00 FFD4 FF20 FF78 FF3D FFDF FF03 FF49 FFF0 FF00 FF00 FF00
0050 FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0060 FF0D FF00 FF03 FF00 FF72 FF24 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0080 FF00 FF21 FFE0 FFFF FF00 FFD4 FF20 FF78 FF3D FFDF FF03 FF49 FFF0 FF00 FF00 FF00
0090 FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00A0 FF0D FF00 FF03 FF00 FF72 FF24 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00C0 FF00 FF21 FFE0 FFFF FF00 FFD4 FF20 FF78 FF3D FFDF FF03 FF49 FFF0 FF00 FF00 FF00
00D0 FF0D FF00 FF03 FF00 FF26 FF21 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00E0 FF0D FF00 FF03 FF00 FF72 FF24 FF04 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
------[ SMBus Device B00-D50 ]------
0000 92 11 0B 02 04 21 00 01 03 11 01 08 0C 00 36 00 .....!........6.
0010 69 78 69 30 69 11 20 89 60 09 3C 3C 00 F0 83 81 ixi0i. .`.<<....
0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 22 00 01 ............."..
0070 00 00 00 00 00 02 9E 01 00 00 00 00 00 00 65 1D ..............e.
0080 43 4D 44 31 36 47 58 33 4D 34 41 32 36 36 36 43 CMD16GX3M4A2666C
0090 31 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12..............
00B0 0C 4A 05 13 01 08 01 08 11 2D 06 48 04 01 3C 4E .J.......-.H..<N
00C0 4E AE 10 D2 20 3E 00 60 09 3C 2A 00 F0 3C 00 00 N... >.`.<*..<..
00D0 0B 00 28 00 00 00 00 00 00 00 00 81 00 00 00 00 ..(.............
------[ SMBus Device B00-D52 ]------
------[ SMBus Device B00-D53 ]------
------[ Chips Found ]------
B00-D51: SPD
B00-D52: SPD
B00-D53: SPD
I had the CPU_FAN connected with something like 1900 rpm I think (goes up to 4500 as it is a water pump). My secondary waterpump was connected to CPU_OPT with hopefully similar readings but as you know, no display in aida. Got my wc radiator fans on CHA_FAN1 with about 900 to 1000 rpm and one on OPT_FAN2 with around 1300 rpm.
