privateman Posted April 9, 2014 Posted April 9, 2014 Hi there, when looking at my notebook battery status with a certain wear level (19% in this case), fully loaded now, 100%, AIDA64 shows the wrong ACTUAL capacity. 59996mWh instead of my actual maximum capacity now of 48374mWh. Or do I get anything wrong? Please help me in understanding, or correct this bug, if possible ;-) Thank you privateman Quote
Fiery Posted April 9, 2014 Posted April 9, 2014 I think that's a bug of the smart logic of the battery itself. The Current Capacity is reported by the battery via a standard Windows API call. Regards, Fiery Quote
privateman Posted April 9, 2014 Author Posted April 9, 2014 Okay ... Are there any other possibilities (WIndows tools?) to have this value checked by other software/tools? Quote
privateman Posted April 9, 2014 Author Posted April 9, 2014 Just found some other software, BatteryMon. Which shows it's a battery bug, as you said, not a software bug. Thanks for your help! Quote
