I saw many beta versions, how do I upgrade?
I bought the license 2 months ago.
I mean the aida64 beta versions which update very frequently.
In order to avoid entering the license key every time I download a new beta version and in order to keep the settings, how do I upgrade to a new beta version aida64 properly?
I did not see any "update online", "check updates" in the menu, why? And how to update?
thank you!
One more thing, I gave my license key to one of my friend, but both are working and aida64 said the key is valid. Why?
If I enter a product key that I got from my friend to Windows 7 in order to activate it, it'll fail....
The activation methods are different, aren't they?
Just download the beta ZIP package, and extract it to the installation folder of AIDA64. Let it overwrite any existing files. Your settings and your license will be kept intact that way.
That is illegal. Please stop spreading your AIDA64 license key!
