errrrrrr Posted June 14, 2014 Posted June 14, 2014 Hello. aida64 is not starting: "Reading MSR Data" Version: 4.50.3000 (May 28, 2014) Ð˜Ð¼Ñ ÐžÐ¡: МайкроÑофт Windows 8.1 Pro ВерÑиÑ: 6.3.9600 Изготовитель: ASUSTeK COMPUTER INC. Модель: N56VB Тип: x64 SKU ÑиÑтемы: ASUS-NotebookSKU ПроцеÑÑор: Intel® Core i5-3230M CPU @ 2.60GHz, 2601 МГц, Ñдер: 2, логичеÑких процеÑÑоров: 4 ВерÑÐ¸Ñ BIOS: American Megatrends Inc. N56VB.202, 21.01.2013 ВерÑÐ¸Ñ SMBIOS: 2.7 ВерÑÐ¸Ñ Ð²Ñтроенного контроллера: 255.255 Режим BIOS: UEFI Изготовитель оÑновной платы: ASUSTeK COMPUTER INC. Папка Windows: C:\WINDOWS СиÑÑ‚ÐµÐ¼Ð½Ð°Ñ Ð¿Ð°Ð¿ÐºÐ°: C:\WINDOWS\system32 УÑтройÑтво загрузки: \Device\HarddiskVolume1 Язык ÑиÑтемы: РоÑÑÐ¸Ñ Ðппаратно-завиÑимый уровень (HAL): ВерÑÐ¸Ñ = "6.3.9600.17031" УÑÑ‚Ð°Ð½Ð¾Ð²Ð»ÐµÐ½Ð½Ð°Ñ Ð¾Ð¿ÐµÑ€Ð°Ñ‚Ð¸Ð²Ð½Ð°Ñ Ð¿Ð°Ð¼ÑÑ‚ÑŒ (RAM): 6,00 ГБ Полный объем физичеÑкой памÑти: 5,89 ГБ ДоÑтупно физичеÑкой памÑти: 3,66 ГБ Ð’Ñего виртуальной памÑти: 11,9 ГБ ДоÑтупно виртуальной памÑти: 9,20 ГБ Размер файла подкачки: 6,00 ГБ Файл подкачки: C:\pagefile.sys 1.txt Quote
Fiery Posted June 14, 2014 Posted June 14, 2014 Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild3011kwx5st2bvczip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps.Thanks, Fiery Quote
errrrrrr Posted June 15, 2014 Author Posted June 15, 2014 sometimes starting, sometimes not starting Quote
Fiery Posted June 17, 2014 Posted June 17, 2014 Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild3016qb2rwxf5vczip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If it still doesn't work, then please start AIDA64 while pressing and holding the left Shift key. It will make AIDA64 display more debug information at startup. Please let me know what is the last message displayed on the splash screen. Quote
Fiery Posted June 20, 2014 Posted June 20, 2014 Thank you for the screen shot. Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild3019t3pf7kczdvzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
errrrrrr Posted June 22, 2014 Author Posted June 22, 2014 Version 4.50.3019 is running! thanx! But does not show all information (CPU) Quote
Fiery Posted June 22, 2014 Posted June 22, 2014 Thank you for the feedback. Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach it as a TXT file to your post. Also, if possible, please attach a CPU-Z v1.69 dump as well. Quote
errrrrrr Posted June 22, 2014 Author Posted June 22, 2014 CPUID & MSR Dump and CPU-Z hang... When accessing the Sensors in aida64 -> BSOD DRIVER_VERIFIER_DETECTED_VIOLATION 0x000000c4 Quote
errrrrrr Posted June 22, 2014 Author Posted June 22, 2014 Load BIOS is default and was all work fine! I apologize for the trouble! Quote
Fiery Posted June 22, 2014 Posted June 22, 2014 I'm glad you've managed to resolve this. I suppose it was due to a BIOS Setup bug. 1 Quote
errrrrrr Posted June 29, 2014 Author Posted June 29, 2014 The problem repeats itself. Turns out it was not in the BIOS When receiving information about the sensors appears BSOD, and CPU-Z hangs on boot: "Processors"... Quote
Fiery Posted June 30, 2014 Posted June 30, 2014 I'm afraid I've run out of ideas about this issue Since other software is also affected, my best guess would be a configuration issue on your system. Due to a BIOS bug, an invalid installed software (that keeps colliding with AIDA64 and CPU-Z), a faulty driver, etc. Quote
