gcampton Posted February 21, 2011 Posted February 21, 2011 So last night I installed AIDA64 for trial purpose, it was great it was showing me CPU temps CPU voltages, gfx temps on gfx volts, and core temps (only cores showed up nothing because it's a dual core unlocked to 3 cores), fan speeds, pretty much everything I could want for a monitoring while stress testing. Today I went to test some more, and the same screen Computer -> Sensor, is showing me nothing except the 3 cores now, naturally all at 0degree's, no volts, no cpu sensor no nothing. Quote
Fiery Posted February 21, 2011 Posted February 21, 2011 Does your Windows user have administrator privileges? AIDA64 needs administrator privileges to perform low-level hardware detection. If privileges are no problem, then please try to reinstall AIDA64. Quote
gcampton Posted February 21, 2011 Author Posted February 21, 2011 Does your Windows user have administrator privileges? AIDA64 needs administrator privileges to perform low-level hardware detection. If privileges are no problem, then please try to reinstall AIDA64. I see, sorry that was my fault. Quote
