LocoChico Posted September 7, 2014 Posted September 7, 2014 Can I just stress test the CPU, or would I test the FPU and/or cache as well? Quote
Fiery Posted September 7, 2014 Posted September 7, 2014 You can use the AIDA64 System Stability Test subtests in any combination you wish Regards, Fiery Quote
LocoChico Posted September 7, 2014 Author Posted September 7, 2014 You can use the AIDA64 System Stability Test subtests in any combination you wish Regards, Fiery So when I'm overclocking it's okay to not test the FPU and cache and just test the CPU? Quote
Fiery Posted September 7, 2014 Posted September 7, 2014 It doesn't a make a difference whether you overclock your system or not. A stable system should be able to perform any subtests in any combinations, without an error. Quote
LocoChico Posted September 7, 2014 Author Posted September 7, 2014 It doesn't a make a difference whether you overclock your system or not. A stable system should be able to perform any subtests in any combinations, without an error. Ok, thanks! Awesome software! Quote
