Hi there,
i try to enable logitech LCD Support but there is always the error:
cannot find DLL (lglcdapi.dll)
trying to get Aida64 on my LCD on G19S.
thx 4 help
1) Do you have the latest Logitech G19 drivers installed? If yes, then please try to reinstall it, and restart Windows.
2) Are you using AIDA64 v4.70? (latest version)
Hi, I'm having this exact same problem with my Logitech G510. I'm running Windows 7 x64. I just installed the newest version of Logitech Gaming Software (8.56.109) from scratch, and the included Logitech LCD applets do work. I'm running the newest version of AIDA64 Extreme. If there's any more info I can give you to help diagnose the problem please let me know.
Cheers.
Thank you. It seems the issue is due to Logitech's Gaming Software package sometimes not being able to insert the necessary keys to the Registry to let 3rd party applications auto-detect the API DLL path. We've added a workaround to handle such issues. Please upgrade to the latest beta version of AIDA64 Extreme available at:
http://www.aida64.com/downloads/aida64extremebuild3215x1k0nqwmldzip
Let me know if it helps.
