Major_A Posted March 4, 2011 Posted March 4, 2011 Me again... This isn't a bug with your program per-say but I was hoping you could help. Every since I bought this board to replace a cheapy ECS that went bad the CPU temps have never been displayed correctly. The computer is located outside (short but embarrassing story)and I live in Texas. Right now the ambient temperature is around 65 degrees Fahrenheit or roughly 18.3 degrees Celsius. Even at this comfortable temp the processor is reporting temperatures right around ambient conditions. I don't have the stock heatsink on the chip but I doubt a $13 92MM tower is that good. It isn't crucial and like I said it might be a problem with the board itself. I haven't ran across a program that gives me what I would think would be the actual temperature. With that said, again, it just might be the board. If you want to poke around with this let me know what info you need. Looking at my Sensor page it also displays that my GPU fan is running at 100%. But the card is a fanless Sapphire card. Again AIDA64 could just be reporting what it's reading from CCC or another source. System Summary: --------[ AIDA64 Extreme Edition ]-------------------------------------------------------------------------------------- Version AIDA64 v1.60.1314 Beta Benchmark Module 2.7.345-x64 Homepage http://www.aida64.com/ Report Type Report Wizard Computer XXXXX Generator XXXXX Operating System Microsoft Windows 7 Ultimate 6.1.7601 (Win7 RTM) Date 2011-03-03 Time 18:26 --------[ Summary ]----------------------------------------------------------------------------------------------------- Computer: Computer Type ACPI x64-based PC Operating System Microsoft Windows 7 Ultimate OS Service Pack Service Pack 1 Internet Explorer 8.0.7601.17514 DirectX DirectX 11.0 Computer Name XXXXX User Name XXXXX Logon Domain XXXXX Date / Time 2011-03-03 / 18:26 Motherboard: CPU Type TripleCore AMD Phenom X3 8450, 2100 MHz (10.5 x 200) Motherboard Name Foxconn M61PMV Series (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video, LAN) Motherboard Chipset nVIDIA nForce 6100-430, AMD K10 System Memory 2048 MB (DDR2-800 DDR2 SDRAM) DIMM1: Micron 8HTF12864AY-800E1 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) DIMM2: Micron 8HTF12864AY-800E1 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) BIOS Type Award (07/01/10) Display: Video Adapter ATI Radeon HD 5450 (512 MB) Video Adapter ATI Radeon HD 5450 (512 MB) 3D Accelerator ATI Radeon HD 5450 (Cedar) Monitor Generic PnP Monitor [NoDB] (H9NY639318) Multimedia: Audio Adapter ATI Radeon HDMI @ ATI Cedar/Park - High Definition Audio Controller Audio Adapter VIA VT1708B CE @ nVIDIA nForce 6100-400/405/420/430 (MCP61) - High Definition Audio Controller Storage: IDE Controller Standard Dual Channel PCI IDE Controller Storage Controller NVIDIA nForce RAID Controller Storage Controller NVIDIA nForce RAID Device Storage Controller NVIDIA nForce RAID Device Storage Controller NVIDIA nForce Serial ATA Controller Storage Controller NVIDIA nForce Serial ATA Controller Disk Drive Generic USB CF Reader USB Device Disk Drive Generic USB MS Reader USB Device Disk Drive Generic USB SD Reader USB Device Disk Drive Generic USB SM Reader USB Device Disk Drive NVIDIA STRIPE 298.10G (298 GB) Disk Drive WDC WD16 00JS-22MHB0 SCSI Disk Device (149 GB) Optical Drive TSSTcorp CDDVDW SH-S223Q SCSI CdRom Device (DVD+R9:16x, DVD-R9:12x, DVD+RW:22x/8x, DVD-RW:22x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM) SMART Hard Disks Status OK Partitions: C: (NTFS) 298.0 GB (268.1 GB free) D: (NTFS) 149.0 GB (148.2 GB free) Total Size 447.0 GB (416.3 GB free) Input: Keyboard Standard PS/2 Keyboard Mouse HID-compliant mouse Network: Primary IP Address XXXXX Primary MAC Address XXXXX Network Adapter Belkin F5D8053 N Wireless USB Adapter Peripherals: Printer Adobe PDF Printer Fax Printer Microsoft XPS Document Writer Infrared Controller Built-in Infrared Device Infrared Controller IrDA Protocol USB1 Controller nVIDIA nForce 6100-400/405/420/430 (MCP61) - OHCI USB 1.1 Controller USB2 Controller nVIDIA nForce 6100-400/405/420/430 (MCP61) - EHCI USB 2.0 Controller USB Device Belkin F5D8053 N Wireless USB Adapter #2 USB Device USB Input Device USB Device USB Mass Storage Device DMI: DMI BIOS Vendor Phoenix Technologies, LTD DMI BIOS Version P10 DMI System Manufacturer FOXCONN DMI System Product M61PMV DMI System Version FAB 1.1 DMI System Serial Number DMI System UUID 00000000-00000000-08070605-04030201 DMI Motherboard Manufacturer FOXCONN DMI Motherboard Product M61PMV DMI Motherboard Version FAB 1.1 DMI Motherboard Serial Number OEM DMI Chassis Manufacturer FOXCONN DMI Chassis Version DMI Chassis Serial Number Unknow DMI Chassis Asset Tag Unknow DMI Chassis Type Desktop Case DMI Total / Free Memory Sockets 2 / 0 EDIT After looking at the report on the site to make sure I deleted personal info I noticed that Unknown is just Unknow. Should be an easy fix. Quote
Fiery Posted March 7, 2011 Posted March 7, 2011 1) The "Unknow" is part of what your BIOS provides under the DMI spec. Please see Q#10 at: http://www.aida64.com/support/knowledge-base 2) The 100% GPU duty cycle is provided by the video card itself, and such weird values are normal when the video card has no fan connected. 3) As for the CPU temperature, maybe the temperature labelled as "Aux" is the actual CPU temperature on your motherboard. Can you please check what happens to the 3 temperatures measured by your motherboard ("CPU", "Motherboard" and "Aux") once you start to load the processor? You can use e.g. AIDA64 System Stability Test to load the processor: go to AIDA64 / main menu / Tools / System Stability Test, uncheck all tests except for "FPU", and press the Start button. Follow the temperatures on the Sensor page, and let us know what conclusion can you draw out of that. Based on your test, we can adjust the temperature labels on the Sensor page. Thanks, Fiery Quote
Major_A Posted March 7, 2011 Author Posted March 7, 2011 Thanks for taking the time to help as always. Here's a picture of the results. If you need more info let me know. Quote
Fiery Posted March 16, 2011 Posted March 16, 2011 We've fixed it up. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1327sv6wdcm3nxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
