Biscum Posted March 4, 2011 Posted March 4, 2011 Dear AIDA Support I recently installed AID64 instead of my old Everest software and I notice a wrong GPU value I recognize that that the GPU temperature Aida 1.60.130 shows for my Geforce 8800 GT is too low. Everest 5.30.1900 is showing the right temeperature for GPU, GPU Ambient and GPU Memory. AIDA64 is showing about the same temperature for GPU and GPU memory. Is is too low GPU temp and value does not rise much when the graphics adapter is under load. Under Everest he GPU temp is rising a lot when adapter is under load For example GPU GPU Ambient GPU Memory AIDA 36 35 36 Everst 44 35 36 Below find the details for AIDA 64 for sensors. NVIDIA GPU registers. Nvidia SMBUS Dump: Sensor Properties Sensor -------------------------------------------------------------------------------- Sensor Properties: Sensor Type ITE IT8718F (ISA 290h) GPU Sensor Type Analog Devices ADT7473 (NV-I2C 2Eh) Motherboard Name Gigabyte EP31 / EP35 / G33 / P31 / P35 Series Chassis Intrusion Detected No Temperatures: Motherboard 40 °C (104 °F) CPU 32 °C (90 °F) CPU #1 / Core #1 47 °C (117 °F) CPU #1 / Core #2 35 °C (95 °F) CPU #1 / Core #3 28 °C (82 °F) CPU #1 / Core #4 41 °C (106 °F) GPU Memory 36 °C (97 °F) OCZ-VERTEX2 3.5 (OCZ-31JXU93NIW13G2Z2) 80 °C (176 °F) OCZ-VERTEX2 3.5 (OCZ-51HM9CRP0PEVCVN0) 1 °C (34 °F) Cooling Fans: CPU 1772 RPM Chassis 1683 RPM Power Supply 548 RPM Fan #4 948 RPM GPU 30% Voltage Values: CPU Core 1.168 V +3.3 V 3.312 V +12 V 12.387 V +5 V Standby 5.188 V VBAT Battery 3.024 V DIMM 2.016 V GPU Core 1.100 V GPU Vcc 3.274 V Debug Info F 017D 0191 04D0 02C8 0000 Debug Info T 40 32 254 Debug Info T 40 32 254 Debug Info T 40 32 254 Debug Info T 40 32 254 Debug Info T 40 32 254 Debug Info T 40 29 254 Debug Info T 40 29 254 Debug Info T 40 29 254 Debug Info T 40 29 254 Debug Info T 40 29 254 Debug Info T 40 29 254 Debug Info V 42 7E CF BB 0F 04 02 C1 BD ITE 87xx HWMonitor Port 0290 ITE 87xx Device ID 8718 ITE 87xx Version 04 Winbond SuperIO HWMonitor Port 0000 Winbond SuperIO Device ID FFFF Fintek SuperIO HWMonitor Port 0000 Fintek SuperIO Device ID 0000 LPC47 SuperIO HWMonitor Port 0000 LPC47 SuperIO Device ID FFFF nVIDIA GPU Registers ------[ AIDA64 v1.60.1300 ]------ ------[ Microsoft Windows 7 Home Premium 6.1.7601 (32-bit) ]------ ------[ Video Adapters ]------ XFX GeForce 8800 GT 512MB [10DE-0611 / 1682-2333] ------[ Video Driver ]------ nvapi.dll: 8.17.12.6658 nvd3dum||8.17.12.6658 - nVIDIA ForceWare 266.58|||nvwgf2um||8.17.12.6658|||nvwgf2um||8.17.12.6658 nvd3dum||8.17.12.6658 - nVIDIA ForceWare 266.58|||nvwgf2um||8.17.12.6658|||nvwgf2um||8.17.12.6658 ------[ nVIDIA GPU #1 @ mem E6000000 ]------ GPU Clocks = 633 / 1620 / 0 MHz Memory Clock = 950 MHz GPU Base Clock = 27000 kHz Shader Base Clock = 27000 kHz Memory Base Clock = 27000 kHz nvidia-000000 = 092880A2 nvidia-0010F0 = 00000000 nvidia-001218 = 00000000 nvidia-001540 = F30F007F nvidia-0015F4 = 00000000 nvidia-0015F8 = 00000000 nvidia-0015FC = 00000000 nvidia-001600 = 00000000 nvidia-001850 = 00000000 nvidia-004000 = 00000000 nvidia-004004 = 00000000 nvidia-004008 = 8018E400 nvidia-00400C = 00002C05 nvidia-004018 = 00001200 nvidia-00401C = 00001C03 nvidia-004020 = 80000000 nvidia-004024 = 00001E02 nvidia-004028 = A0000000 nvidia-00402C = 00002907 nvidia-00C040 = 2E80DBB3 nvidia-00E114 = 00000001 nvidia-00E118 = 00000000 nvidia-00E11C = 00000001 nvidia-00E120 = 00000000 nvidia-020008 = C0083658 nvidia-020014 = FE5B0384 nvidia-020400 = 00000000 nvidia-100000 = 0000C042 nvidia-100200 = 01001000 nvidia-10020C = 20000000 nvidia-100214 = 00002222 nvidia-100474 = 00000000 nvidia-100714 = 00033122 nvidia-100914 = 00000000 nvidia-101000 = 9F42C48A nvidia-300000 = EB73AA55 nvidia-310000 = EB73AA55 nvidia-700000 = 04010008 nvidia-7E0000 = EB73AA55 ------[ nVIDIA GPU #1 / ForceWare Properties ]------ Memory Type = 5 (GDDR3) Memory Bank Count = 1 Memory Bus Width = 256-bit GPU / MC / VE Load = 2 / 1 / 0 VPE Count = 0 Shader Pipe Count = 7 Shader SubPipe Count = 2 Total SP Count = 112 Total TPC Count = 7 Total SM Count = 14 Core Count = 112 Partition Count = 4 Fan RPM = <unknown> Core Voltage = 1100 mV Current Pstate = 0 Ventura State = 0 (unsupported) Physical Frame Buffer Size = 524288 KB Virtual Frame Buffer Size = 1835008 KB Total / Free Video Memory = 524288 KB / 428472 KB ------[ nVIDIA GPU #1 / ForceWare Clocks ]------ Perf. Levels = 1 Active Profile = 0 curr-core/shader/mem-0 = 640 MHz / 1600 MHz / 950 MHz [Active] orig-core/shader/mem-0 = 640 MHz / 1600 MHz / 950 MHz [Active] ------[ nVIDIA GPU #1 / BIOS Info ]------ BIOS Version = 62.92.16.00.A6 Signon Message = GeForce 8800 GT VGA BIOS Bootup Core Clock = 400 MHz Bootup Shader Clock = 800 MHz Bootup Mem Clock = 400 MHz Ref. Clock 4000 = 0 kHz = 0 MHz *4 Ref. Clock 4008 = 108000 kHz = 27 MHz *4 [Memory] Ref. Clock 4010 = 0 kHz = 0 MHz *4 Ref. Clock 4018 = 0 kHz = 0 MHz *4 Ref. Clock 4020 = 108000 kHz = 27 MHz *4 [shader] Ref. Clock 4028 = 108000 kHz = 27 MHz *4 [GPU] Ref. Clock 4030 = 108000 kHz = 27 MHz *4 Ref. Clock 4038 = 0 kHz = 0 MHz *4 Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 100 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 100 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 100 % Core Clock = 640 MHz Shader Clock = 1600 MHz Mem Clock = 950 MHz Geom. Delta = 128 MHz Core Voltage = 0.00 V Fan Speed = 100 % Diode Gain Mul = 10 Diode Gain Div = 187 Diode Offset Mul = -130963 Diode Offset Div = 187 Diode Offset Bin Mul = 0 Diode Offset Bin Div = 1 Temp Compensation Mul = 1496 Temp Compensation Div = 1 Max Div = 187 Measured Temp Threshold (Raw) = 0 Measured Temp Threshold (Int) = 0 Celsius Measured Temp Threshold (Float) = 0 Celsius BIOS Temp Threshold = 110 Celsius Measured Diode Temp (Raw) = 900 Measured Diode Temp (Int) = -644 Celsius Measured Diode Temp (Float) = -644 Celsius Diode Temp by ForceWare = 45 Celsius ------[ NVAPI GPU Handles ]------ GPU Count = 1 GPU #1 = BB000100 ------[ nVIDIA GPU #1 / Thermal Settings ]------ Sensor Count = 2 Sensor #0 / Controller = VBIOSEVT Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 45 Celsius Sensor #1 / Controller = VBIOSEVT Sensor #1 / Target = GPU Board Ambient Sensor #1 / Current Temp = 35 Celsius NVIDIA SMBus Dump ------[ AIDA64 v1.60.1300 ]------ ------[ Microsoft Windows 7 Home Premium 6.1.7601 (32-bit) ]------ ------[ Video Adapters ]------ XFX GeForce 8800 GT 512MB [10DE-0611 / 1682-2333] ------[ Video Driver ]------ nvapi.dll: 8.17.12.6658 nvd3dum||8.17.12.6658 - nVIDIA ForceWare 266.58|||nvwgf2um||8.17.12.6658|||nvwgf2um||8.17.12.6658 nvd3dum||8.17.12.6658 - nVIDIA ForceWare 266.58|||nvwgf2um||8.17.12.6658|||nvwgf2um||8.17.12.6658 ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B00-D36 ]------ 0000 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0010 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0020 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0030 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0040 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0050 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0060 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0070 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0080 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 0090 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 00A0 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 00B0 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 00C0 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 00D0 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 00E0 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr 00F0 DA 07 76 19 97 26 2B 45 11 91 E2 2C 00 11 4E 72 ..v..&+E...,..Nr ------[ nVIDIA SMBus Device GPU #1 / B00-D36 ]------ 0000 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0010 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0020 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0030 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0040 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0050 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0060 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0070 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0080 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 0090 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 00A0 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 00B0 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 00C0 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 00D0 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 00E0 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E 00F0 07DA 1976 2697 452B 9111 2CE2 1100 724E 07DA 1976 2697 452B 9111 2CE2 1100 724E ------[ nVIDIA SMBus Device GPU #1 / B00-D37 ]------ 0000 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0010 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0020 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0030 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0040 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0050 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0060 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0070 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0080 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 0090 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 00A0 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 00B0 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 00C0 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 00D0 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 00E0 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF 00F0 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF ------[ nVIDIA SMBus Device GPU #1 / B00-D37 ]------ 0000 4646 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0010 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0020 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0030 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0040 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0050 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0060 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0070 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0080 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 0090 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 00A0 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 00B0 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 00C0 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 00D0 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 00E0 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 00F0 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D 467D ------[ nVIDIA SMBus Device GPU #1 / B00-D3A ]------ 0000 B7 16 3E 34 C8 00 00 00 00 00 00 00 00 00 00 00 ..>4............ 0010 40 01 04 02 00 00 00 00 EA 0B 42 10 10 00 40 A2 @.........B...@. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B00-D3A ]------ 0000 16B7 3E16 343E C834 00C8 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 4000 0010 0140 0401 0204 0002 0000 0000 0000 EA00 0BEA 420B 1042 1010 0010 4000 A240 00A2 0020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 9100 0040 0091 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 B700 ------[ nVIDIA SMBus Device GPU #1 / B00-D4A ]------ 0000 2F 2F 2F 2F 2F 2F F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 //////.......... 0010 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0020 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0030 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0040 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0050 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0060 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0070 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0080 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0090 F0 F0 F0 F0 00 00 00 00 00 00 00 00 00 00 F0 F0 ................ 00A0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00B0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00C0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00D0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00E0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ ------[ nVIDIA SMBus Device GPU #1 / B00-D4A ]------ 0000 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0010 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0020 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0030 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0040 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0050 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0060 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0070 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0080 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0090 F0F0 F0F0 F0F0 F0F0 0000 0000 0000 0000 0000 0000 0000 0000 F0F0 F0F0 F0F0 F0F0 00A0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00B0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00C0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00D0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00E0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 ------[ nVIDIA SMBus Device GPU #1 / B00-D4B ]------ 0000 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0010 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0020 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0030 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0040 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0050 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0060 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0070 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0080 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 0090 F0 F0 F0 F0 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00C0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00D0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00E0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ 00F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 F0 ................ ------[ nVIDIA SMBus Device GPU #1 / B00-D4B ]------ 0000 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0010 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0020 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0030 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0040 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0050 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0060 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0070 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0080 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 0090 F0F0 F0F0 F0F0 00F0 0000 F000 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00A0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00B0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00C0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00D0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00E0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 00F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 F0F0 ------[ nVIDIA SMBus Device GPU #1 / B00-D50 ]------ 0000 00 FF FF FF FF FF FF 00 09 D1 5A 78 45 54 00 00 ..........ZxET.. 0010 2E 13 01 03 80 30 1B 78 2E E6 15 A6 55 49 99 27 .....0.x....UI.' 0020 13 50 54 BF EF 80 71 00 71 4F 81 C0 81 00 81 40 .PT...q.qO.....@ 0030 95 00 95 0F B3 00 02 3A 80 18 71 38 2D 40 58 2C .......:..q8-@X, 0040 45 00 DE 0D 11 00 00 1E 00 00 00 FF 00 42 42 39 E............BB9 0050 30 31 33 31 30 30 32 36 0A 20 00 00 00 FD 00 32 01310026. .....2 0060 4C 18 53 15 00 0A 20 20 20 20 20 20 00 00 00 FC L.S... .... 0070 00 42 65 6E 51 47 32 32 32 32 48 44 4C 0A 00 2F .BenQG2222HDL../ 0080 00 FF FF FF FF FF FF 00 09 D1 5A 78 45 54 00 00 ..........ZxET.. 0090 2E 13 01 03 80 30 1B 78 2E E6 15 A6 55 49 99 27 .....0.x....UI.' 00A0 13 50 54 BF EF 80 71 00 71 4F 81 C0 81 00 81 40 .PT...q.qO.....@ 00B0 95 00 95 0F B3 00 02 3A 80 18 71 38 2D 40 58 2C .......:..q8-@X, 00C0 45 00 DE 0D 11 00 00 1E 00 00 00 FF 00 42 42 39 E............BB9 00D0 30 31 33 31 30 30 32 36 0A 20 00 00 00 FD 00 32 01310026. .....2 00E0 4C 18 53 15 00 0A 20 20 20 20 20 20 00 00 00 FC L.S... .... 00F0 00 42 65 6E 51 47 32 32 32 32 48 44 4C 0A 00 2F .BenQG2222HDL../ ------[ nVIDIA SMBus Device GPU #1 / B00-D50 ]------ 0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 0900 D109 5AD1 785A 4578 5445 0054 0000 2E00 0010 132E 0113 0301 8003 3080 1B30 781B 2E78 E62E 15E6 A615 55A6 4955 9949 2799 1327 0020 5013 5450 BF54 EFBF 80EF 7180 0071 7100 4F71 814F C081 81C0 0081 8100 4081 9540 0030 0095 9500 0F95 B30F 00B3 0200 3A02 803A 1880 7118 3871 2D38 402D 5840 2C58 452C 0040 0045 DE00 0DDE 110D 0011 0000 1E00 001E 0000 0000 FF00 00FF 4200 4242 3942 3039 0050 3130 3331 3133 3031 3030 3230 3632 0A36 200A 0020 0000 0000 FD00 00FD 3200 4C32 0060 184C 5318 1553 0015 0A00 200A 2020 2020 2020 2020 2020 0020 0000 0000 FC00 00FC 0070 4200 6542 6E65 516E 4751 3247 3232 3232 3232 4832 4448 4C44 0A4C 000A 2F00 002F 0080 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 0900 D109 5AD1 785A 4578 5445 0054 0000 2E00 0090 132E 0113 0301 8003 3080 1B30 781B 2E78 E62E 15E6 A615 55A6 4955 9949 2799 1327 00A0 5013 5450 BF54 EFBF 80EF 7180 0071 7100 4F71 814F C081 81C0 0081 8100 4081 9540 00B0 0095 9500 0F95 B30F 00B3 0200 3A02 803A 1880 7118 3871 2D38 402D 5840 2C58 452C 00C0 0045 DE00 0DDE 110D 0011 0000 1E00 001E 0000 0000 FF00 00FF 4200 4242 3942 3039 00D0 3130 3331 3133 3031 3030 3230 3632 0A36 200A 0020 0000 0000 FD00 00FD 3200 4C32 00E0 184C 5318 1553 0015 0A00 200A 2020 2020 2020 2020 2020 0020 0000 0000 FC00 00FC 00F0 4200 6542 6E65 516E 4751 3247 3232 3232 3232 4832 4448 4C44 0A4C 000A 2F00 002F ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B03-D0C ]------ 0000 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0010 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0020 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0030 5D 5D 5D 5D 5D 5D 5D 5D 5D 4F 5D 5D FF FF 5D 5D ]]]]]]]]]O]]..]] 0040 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0050 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0060 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0070 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0080 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0090 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00A0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00B0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00C0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00D0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00E0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00F0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] ------[ nVIDIA SMBus Device GPU #1 / B03-D0C ]------ 0000 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D FFFF FFFF FFFF 7E5D 7E5D FFFF FFFF 7E5D 7E5D 7E5D 0010 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0020 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0030 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0040 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0050 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0060 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0070 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0080 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 0090 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 00A0 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 00B0 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D FFFF FFFF 7E5D 7E5D 00C0 7E5D FFFF 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 00D0 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 00E0 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 00F0 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D 7E5D ------[ nVIDIA SMBus Device GPU #1 / B03-D2E ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 FF BE 00 00 65 63 65 FF FF FF FF FF FF FF FF .....ece........ 0030 4C FF 00 9A 62 A4 20 00 FF FF FF 00 00 73 41 69 L...b. ......sAi 0040 45 D0 10 1F 00 FF 00 FF 00 F1 FF FF 00 FF FF FF E............... 0050 54 7C 90 A9 FF FF FF FF 00 80 FF FF 02 60 80 C8 T|...........`.. 0060 CC CC 20 00 4C 80 80 8A 64 9A A4 A4 B5 24 40 00 .. .L...d....$@. 0070 00 00 00 00 CF FF 2C 20 1E 00 00 57 30 01 00 00 ......, ...W0... 0080 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B03-D2E ]------ 0000 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 0010 E500 E500 4D03 E500 FFFF E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 0020 E500 16FF D6BE E500 E500 D965 CB63 D965 16FF 16FF 16FF 16FF 16FF 16FF 16FF 16FF 0030 064C 16FF E500 2A9A CC62 90A4 0520 E500 16FF 16FF 16FF E500 E500 BB73 2541 FD69 0040 3945 DBD0 9510 B81F E500 16FF E500 16FF E500 16FF E500 16FF E500 16FF 1C90 90A4 0050 4E54 967C 1C90 B3A9 16FF 16FF 16FF 16FF E500 6C80 16FF 16FF EB02 C260 6C80 93C8 0060 8FCC 8FCC 0520 E500 064C 6C80 6C80 5A8A DE64 2A9A 90A4 90A4 E7B5 1924 2240 E500 0070 E500 E500 E500 E500 86CF 16FF 212C 0520 BF1E E500 E500 4757 7530 E201 E500 E500 0080 9510 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 0090 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00A0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00B0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00C0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 FFFF FFFF FFFF E500 E500 FFFF 00D0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00E0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00F0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 Quote
Fiery Posted March 10, 2011 Posted March 10, 2011 Thank you. We've fixed the GPU temperature on 8800GT cards in the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1321m5sk0lyfxczip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
Biscum Posted March 12, 2011 Author Posted March 12, 2011 Hello Fiery Works like a charm Many thanks for your fast so;utiom Best regards Biscum Quote
