smokahontas Posted March 11, 2011 Posted March 11, 2011 why I shows the CPU temperature 80-88 ° C? i5 2400 , p8p67-m pro sorry for my english 1 Quote
Fiery Posted March 13, 2011 Posted March 13, 2011 1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. 2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic. 3) Then copy-paste the full content of the Computer / Sensor page of AIDA64 into this topic. Using those dumps we can check what's wrong with the temperature measurement in AIDA64. Thanks, Fiery 1 Quote
smokahontas Posted March 13, 2011 Author Posted March 13, 2011 here isasensordump.txtFetching info... Report.txtFetching info... smbusdump_full.txtFetching info... 1 Quote
Fiery Posted March 16, 2011 Posted March 16, 2011 Thank you for the dumps. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1327sv6wdcm3nxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. In case the temperatures are still not right, or the "CPU" temperature is missing, then please create a new ISA Sensor Dump using this new beta, and copy-paste it to this topic so we can check out what's happening. Thanks, Fiery 1 Quote
smokahontas Posted March 16, 2011 Author Posted March 16, 2011 thanks isasensordump.txtFetching info... Report.txtFetching info... smbusdump_full.txtFetching info... 1 Quote
Fiery Posted March 22, 2011 Posted March 22, 2011 Thank you, we've implemented the temperature readouts in the following beta release of AIDA64: http://www.aida64.com/downloads/aida64extremebuild1333ty4wmqx2hczip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Please note that there's a slim chance the measured CPU temperature is lower by a fixed value (e.g. by 10 Celsius) than the actual one. In such case, both at idle and under load a certain offset will be shown compared to the actual CPU temperature. In case you have an Asus temperature monitoring software on hand, you can verify the CPU temperature using that. Thanks, Fiery 1 Quote
smokahontas Posted March 23, 2011 Author Posted March 23, 2011 isasensordump.txtFetching info... Report.txtFetching info... smbusdump_full.txtFetching info... 1 Quote
Fiery Posted March 23, 2011 Posted March 23, 2011 Thank you. So it seems AIDA64 measures the same weirdly low CPU temperature as Asus' software It may be a hardware implementation issue. 1 Quote
smokahontas Posted March 23, 2011 Author Posted March 23, 2011 as shown in the BIOS Thank you for your support 1 Quote
