SUPREMACY Posted April 30, 2015 Posted April 30, 2015 Hi: sorry for my bad english. I have a asrock z77 extreme-4 mobo, CPU i5 3470, corsir cooler H100i, my grafic card is IGPU, aidas and other software report 55 degrees in the PCH diode, my ambient temp is 32 or 33 degrees for this temp in the PCH diode. at this moment the ambient temp is 28 degrees, and humidity is 74 percent and my temp is: Placa base 34 °C (93 °F) CPU 32 °C (90 °F) CPU # 1 / núcleo # 1 32 °C (90 °F) CPU # 1 / núcleo # 2 31 °C (88 °F) CPU # 1 / núcleo # 3 33 °C (91 °F) CPU # 1 / núcleo # 4 29 °C (84 °F) Diodo PCH 50 °C (122 °F) PD: this temp is in destock, playing music, open web navigator, my CPU not activate turbo boost tecnology, and may case is corsair carbiden 500R, tehe series fan replacent for cooler master sikeflow work 1850RPM, and the cooler side is replacen for in win cooler fan 140mm. I am worried for his temp in the PCH diode, and other moment wthis the ambient temp is 26 o 27 degrees the PCH temp is 43 or 44 degrees.This valued is very highs or is normal. Quote
Fiery Posted May 1, 2015 Posted May 1, 2015 It is normal, you don't have to worry about it. Chipset components like PCH, MCH, FCH and MCP tend to work at considerably higher temperatures than other motherboard components. Regards, Fiery Quote
SUPREMACY Posted May 1, 2015 Author Posted May 1, 2015 It is normal, you don't have to worry about it. Chipset components like PCH, MCH, FCH and MCP tend to work at considerably higher temperatures than other motherboard components. Regards, Fiery thanks for your replay, this is very important for me because I was very worried about it. In this moment the ambient temp is 27 Celcius degrees, and the PCH DIODE works at 47 Celcius degrees. attaching imagen for aidas stability test for 7 minutes. Quote
SUPREMACY Posted May 1, 2015 Author Posted May 1, 2015 It is normal, you don't have to worry about it. Chipset components like PCH, MCH, FCH and MCP tend to work at considerably higher temperatures than other motherboard components. Regards, Fiery thanks for your replay, this is very important for me because I was very worried about it. In this moment the ambient temp is 27 Celcius degrees, and the PCH DIODE works at 47 Celcius degrees. attaching imagen for aidas stability test for 7 minutes. best regards. ransel. Quote
Fiery Posted May 1, 2015 Posted May 1, 2015 attaching imagen for aidas stability test for 7 minutes. That looks just fine. Those CPU core temperatures are quite good considering the CPU was under heavy load. Quote
Henantier Posted June 20, 2015 Posted June 20, 2015 It is normal, you don't have to worry about it. Chipset components like PCH, MCH, FCH and MCP tend to work at considerably higher temperatures than other motherboard components. Regards, Fiery hello! My laptop DELL INSPIRON 5110n (core-i3, gt 525m) I have next temp: Температуры ЦП 56 °C (133 °F) CPU Package 57 °C (135 °F) CPU IA Cores 57 °C (135 °F) CPU GT Cores 56 °C (133 °F) ЦП 1 / Ядро 1 56 °C (133 °F) ЦП 1 / Ядро 2 57 °C (135 °F) ЧипÑет 16 °C (61 °F) Диод PCH 83 °C (181 °F) Aux 49 °C (120 °F) DIMM 51 °C (124 °F) WDC WD2500BEKT-75PVMT1 57 °C (135 °F) it`s normal too? Quote
