Aida64 Motherboard/Motherboard - no motherboard physical info (MSI 2AE0)
My PCs summary at "Motherboard / Motherboard / No motherboard phsical info" is not displayed.  System specs are:
Motherboard:  MSI 2
Chipset: AMD Hudson-3, AMD K15.1
CPU Type QuadCore AMD A8-5500, 3500 MHz (35 x 100)
Is my system lacking a sensor etc. that summarizes this info?  In advance thanks for your time and support.
"MSI 2" seems like an incorrect (maybe truncated?) motherboard model. We can check it out, as well as the sensor issue, if you could post an ISA Sensor Dump of your system. Right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic.
I apologize for the incomplete motherboard model.  Attached is the recommende ISA Sensor Dump:
------[ AIDA64 Extreme v5.20.3400 ]------
------[ Microsoft Windows 8.1 6.3.9600.17736 (64-bit) ]------
Motherboard ID      : 63-0100-000001-00101111-122211-Chipset$JAS818_BIOS DATE: 09/04/13 09:36:08 VER: 04.06.05
Motherboard Model   : MSI 2AE0
Motherboard Chipset : AMD A75, AMD K15.1
DMI MB Manufacturer : MSI
DMI MB Product      : 2AE0
DMI MB Version      : 1.0
DMI MB Serial       :
DMI SYS Manufacturer: Hewlett-Packard
DMI SYS Product     : p7-1534
DMI SYS Version     :
DMI SYS Serial      : MXX3170714
DMI BIOS Version    : 8.18
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h (0000h / 0000h)
ITE SuperIO Device ID      = 0000h (0000h / 0000h)
ITE SuperIO Version        = 00h   (  00h /   00h)
Winbond SuperIO Port              = 00h
Winbond SuperIO Device ID         = 1001h (0000h / 1001h)
Fintek SuperIO Port           = 4Eh
Fintek SuperIO HWMonitor Port = 0600h (0000h / 0600h)
Fintek SuperIO Device ID      = 1001h (0000h / 1001h)
SMSC SuperIO Port           = 00h
SMSC SuperIO Device ID      = 0000h (0000h / 0000h)
ASpeed SuperIO Port = 00h
------[ LM78 ISA Sensor Device at 0600 ]------
0000  FF 03 00 00  FF FF FF FF  98 FF 01 00  55 00 FF C0
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  D0 00 00 00  FF FF FF D0  D5 FF FF FF  FF 33 5B 7F
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  44 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 FF 00 00  00 FF FF 04  40 04 FF 00
0070  FF FF E7 FF  1D FF FF FF  FF FF 00 00  00 07 00 00
0080  FF FF 64 55  64 55 FF FF  FF FF FF FF  FF FF FF FF
0090  00 04 04 60  26 FF 05 FF  55 FF FF 05  55 FF 66 00
00A0  06 75 00 33  03 FF 46 46  32 23 FF FF  66 66 33 9C
00B0  06 75 00 5B  03 FF 46 46  32 23 FF FF  BA BA 5B 9C
00C0  0F FF FF 7F  FF FF FF FF  FF FF FF FF  FF FF FF 00
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00E0  07 00 00 00  00 FF FF FF  FF FF FF FF  00 01 01 02
00F0  FF FF FF FF  FF FF 3B FF  FF FF FF FF  23 FF FF FF
   0070 0072 0074 0076 0078 0079 007A 007B 007C 007D 007E 007F
T:  255  231   29  255  255  255    0    0    0    7    0    0
T:  255  231   29  255  255  255    4    0    0    6    0    0
T:  255  231   29  255  255  255    5    0    0    5    0    0
T:  255  231   29  255  255  255    4    0    0    3    0    0
T:  255  231   29  255  255  255    3    0    0    2    0    0
T:  255  231   29  255  255  255    2    0    0    1    0    0
   0020 0021 0022 0023 0024 0025 0026 0027 0028
V:  D0   00   00   00   FF   FF   FF   D0   D5   [ VID = 1.38750 V ]
V:  D0   00   00   00   FF   FF   FF   D0   D5   [ VID = 0.92500 V ]
------[ Hudson-2/3/4 PM2 at 0CD0 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0010  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0020  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0040  00 00 00 00  00 00 00 00  00 00 00 00  00 00 FF FF
0060  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0070  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 00 00 00  00 00 00 00  00 FF FF 00  00 00 00 00
00B0  00 FF 00 00  FF 00 00 FF  00 00 00 00  00 00 00 00
00C0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  FF FF FF FF  FF 00 FF 00
00E0  00 00 00 00  00 00 00 00  00 00 83 1F  01 00 00 02
00F0  19 0A 02 05  C8 20 80 00  04 06 00 55  08 08 00 02
Reg$59VIN0:  r = $FFFF,  r*0.000046 = 3.0146
Reg$5DVIN1:  r = $FFFF,  r*0.000046 = 3.0146
Reg$61VIN2:  r = $0000,  r*0.000046 = 0.0000
Reg$65VIN3:  r = $0000,  r*0.000046 = 0.0000
Reg$69VIN4:  r = $0000,  r*0.000046 = 0.0000
Reg$6DVIN5:  r = $0000,  r*0.000046 = 0.0000
Reg$71VIN6:  r = $0000,  r*0.000046 = 0.0000
Reg$75VIN7:  r = $0000,  r*0.000046 = 0.0000
------[ Hudson-2/3/4 PM at 0CD6 ]------
0000  0E 00 4F 4A  00 04 00 02  34 05 04 02  06 21 43 55
0010  FF 0F 00 00  FF 0F 00 00  00 00 00 00  00 00 00 00
0020  00 00 D1 FE  01 00 D8 FE  25 0B 80 00  01 0B 00 00
0030  00 00 00 00  07 00 C0 FE  0C 00 00 00  00 00 00 00
0040  00 00 00 00  00 00 00 00  F1 00 C0 FE  03 00 00 00
0050  01 00 D0 FE  D0 00 00 97  01 FF 15 66  00 05 00 07
0060  00 08 04 08  08 08 10 08  20 08 B2 00  00 FE BA 00
0070  00 00 00 00  17 00 00 4C  FF FF 00 00  FF FF E0 81
0080  00 18 26 28  00 00 00 00  00 00 00 00  9E 00 80 00
0090  02 05 02 0B  0A 00 10 00  00 10 00 01  00 00 00 00
00A0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00B0  00 00 8A 00  80 00 05 05  88 00 08 44  02 00 53 C0
00C0  F9 07 58 40  2C 00 00 00  2C 40 28 00  F9 FF FF FF
00D0  00 F4 38 BF  00 00 20 00  1E 0B 99 00  01 00 10 03
00E0  D8 0C 00 00  00 00 00 02  00 00 01 01  03 17 00 CF
00F0  9C 73 07 00  00 00 00 21  6C 07 00 00  00 00 00 00
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
