pUNKrOCK Posted March 22, 2011 Posted March 22, 2011 Aida64 Extreme Edition wrong cpu temps ! Screen: is this a bug in the program or is this normal? 10 degrees is a lot of difference! Quote
pUNKrOCK Posted March 22, 2011 Author Posted March 22, 2011 Sensoreigenschappen Sensortype Winbond W83667HG (ISA 290h) GPU sensortype Diode (ATI-Diode) Moederbordnaam Asus Maximus II Series Chassis inbreuk opgemerkt Nee Temperaturen Moederbord 29 °C (84 °F) CPU 20 °C (68 °F) CPU #1 / Kern #1 18 °C (64 °F) CPU #1 / Kern #2 20 °C (68 °F) CPU #1 / Kern #3 14 °C (57 °F) CPU #1 / Kern #4 14 °C (57 °F) North Bridge 40 °C (104 °F) South Bridge 41 °C (106 °F) PWM 34 °C (93 °F) GPU diode (DispIO) 26 °C (79 °F) GPU diode (MemIO) 20 °C (68 °F) GPU diode (shader) 22 °C (72 °F) WDC WD10EADS-00L5B1 22 °C (72 °F) WDC WD20EARS-00MVWB0 21 °C (70 °F) WDC WD3000GLFS-01F8U0 21 °C (70 °F) OCZ-VERTEX2 (OCZ-KTZ4019HZ972I639) 30 °C (86 °F) OCZ-VERTEX2 (OCZ-MUL06SXC9DI070FP) 30 °C (86 °F) Koelingsventilatoren CPU 4441 RPM GPU 24% Spanningswaarde CPU Core 1.496 V +3.3 V 3.312 V +5 V 5.016 V +12 V 12.096 V +5 V Standby 5.164 V CPU VTT 1.290 V CPU PLL 1.786 V North Bridge +1.1 V 1.316 V South Bridge +1.1 V 1.124 V South Bridge +1.5 V 1.501 V DIMM 2.203 V DIMM VTT 1.098 V Stroomwaardes CPU 24.97 A Stroomverbruikwaardes CPU 37.69 W Debug Info F FF 4B FF / FF FF Debug Info T 28 21 26 Debug Info V BC D7 D1 CF D1 FF 99 (03) Debug Info I C1 A513 ------[ Motherboard Info ]------ Motherboard ID : 65-2302-000001-00101111-041510-Eaglelake$A1007001_BIOS DATE: 04/15/10 17:15:35 VER: 08.00.14 Motherboard Model : Asus Maximus II Formula Motherboard Chipset : Intel Eaglelake P45 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : Maximus II Formula DMI MB Version : Rev 1.xx DMI MB Serial : MS1C87BLTG01213 DMI SYS Manufacturer: System manufacturer DMI SYS Product : Maximus II Formula DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 2302 ------[ GPIO @ isa 0500 ]------ 0000 C2 75 FD 19 C3 7F 6F E0 00 00 00 00 FF FE FF E2 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 08 00 00 00 00 00 00 00 00 00 C0 24 00 00 0030 FF 00 03 03 50 FF 55 0D 83 FF FE 0F 00 00 00 00 ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 2Eh Winbond SuperIO HWMonitor Port = 0290h Winbond SuperIO Device ID = A513h Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1 Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0290 ]------ 0000 04 FF 04 FF 00 00 3C 20 01 9B 01 01 3C 3C 04 04 0010 04 FF 30 00 00 01 01 3C 43 17 00 00 1D FF FF CD 0020 BB D8 D1 CF D1 FF 99 1B FF 4C FF DA 00 07 80 02 0030 90 20 00 00 04 20 00 44 AB 8D 16 14 00 24 C0 FF 0040 03 DE 00 FF FF 00 3F B5 2D 21 20 C0 90 95 00 A3 0050 FF FF 00 FF FF FF 00 80 C1 FF FF FF 19 A4 04 05 0060 04 FF 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 00 0070 00 00 00 00 00 FF FF FF FF FF FF 4B 22 00 1B FF 0080 04 FF 04 FF 00 00 3C 20 01 9B 01 01 3C 3C 04 04 0090 04 FF 30 00 00 01 01 3C 43 17 00 00 1D FF FF CD 00A0 BB D8 D1 CF D1 FF 99 1B FF 4C FF DA 00 07 80 02 00B0 90 20 00 00 04 20 00 44 AB 8D 16 14 00 24 C0 FF 00C0 03 00 00 FF FF 00 3F B5 2D 21 20 C0 90 95 00 A3 00D0 FF FF 00 FF FF FF 00 80 C1 FF FF FF 19 A4 04 05 00E0 04 FF 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 00 00F0 00 00 00 00 00 FF FF FF FF FF FF 4B 22 00 1B FF Bnk0 FF FF 00 FF FF FF 00 80 C1 FF FF FF 19 A4 04 05 Bnk1 15 80 00 4B 00 50 04 FE FF FF FF FF FF FF FF FF Bnk2 1A 80 00 4B 00 50 1B 40 FF FF FF FF FF FF FF FF Bnk3 01 00 03 02 04 03 01 06 02 00 00 C0 26 03 00 00 Bnk4 3B 13 FF 00 00 F7 00 0B 7F DE 1D BB 09 5F 20 7F Bnk5 D5 01 00 FF 28 40 11 18 02 20 00 00 41 00 00 00 Bnk6 7F 7F 7F 7F 7F 7F 00 00 11 58 00 00 00 00 00 00 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ Asus ATK0110 ]------ Motherboard ID: P5Q-Deluxe ICPU/VCPU/PCPU: 36 / 16 / 58205 CPU Temperature : 21.5 C MB Temperature : 29.0 C NB Temperature : 40.0 C OPT_FAN1 Temperature: 0.0 C OPT_FAN2 Temperature: 0.0 C OPT_FAN3 Temperature: 0.0 C POWER Temperature : 34.0 C SB Temperature : 41.0 C CH_FAN1 Speed : 0 RPM CH_FAN2 Speed : 0 RPM CH_FAN3 Speed : 0 RPM CPU FAN Speed : 4440 RPM OPT1_FAN Speed : 0 RPM OPT2_FAN Speed : 0 RPM OPT3_FAN Speed : 0 RPM Power_FAN Speed : 0 RPM +12 Voltage : 12.096 V +3.3 Voltage : 3.312 V +5 Voltage : 5.016 V CPUPLL Voltage : 1.786 V DDR Voltage : 2.203 V Dram VTT Volt : 1.111 V NB11 Voltage : 1.323 V SB11 Voltage : 1.124 V SB15 Voltage : 1.501 V Vcore Voltage : 1.515 V VTTCPU Voltage : 1.290 V CPU Temperature : 153.7 C MB Temperature : 154.4 C Chassis FAN Speed : 1539 RPM CPU FAN Speed : 1538 RPM Power FAN Speed : 1540 RPM +12V Voltage : 1.541 V +3.3V Voltage : 1.543 V +5V Voltage : 1.542 V Vcore Voltage : 1.536 V CPU Frequency : 400.00 MHz PCIE Frequency : 100.00 MHz DRAM Frequency : 1066 MHz CPU Ratio : 9.0x ========================================================================== ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel ICH SMBus Port : 0400 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D20 ]------ 0000 FF 80 17 7F FF FF FF FF FF FF FF FF FF FF FF FF ............... 0010 00 FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF ................ 0020 20 00 FF FF FF 20 B2 FF FF FF FF FF FF FF FF FF .... .......... 0030 FF FF FF FF FF FF FF FF 74 03 FF FF FF FF FF FF ........t....... 0040 FF FF FF FF FF FF FF FF FF FF 64 FF FF FF FF FF ..........d..... 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF 2C FF FF FF FF FF ..........,..... 0070 FF FF FF FF FF FF FF FF 02 08 00 00 FF FF 80 FF ................ 0080 00 FF FF FF FF FF FF FF FF FF FF 0F 3D FF FF FF ............=... 0090 FF FF FF FF FF FF 64 FF FF 41 98 01 FF FF FF FF ......d..A...... 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 00 03 72 72 03 02 01 02 95 00 00 00 00 00 00 00 ..rr............ 00E0 00 00 10 0C 10 10 17 10 10 10 10 FF 07 FF 00 FF ................ 00F0 FF 25 FF FF FF 02 02 FF FF 00 00 50 FF FF FF FF .%.........P.... ------[ SMBus Device B00-D20 ]------ 0000 FFFF 3780 6617 FF7F FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 7700 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 54B0 FFFF FFFF FFFF FFFF FFFF FFFF 0020 7620 0000 FFFF FFFF FFFF 0020 00B2 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0074 0003 FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0064 FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 012C FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ED02 0208 3500 5E00 FFFF FFFF 1982 FFFF 0080 DE00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0011 E257 FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF E390 FFFF FFFF 8641 3298 9701 FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FA00 9803 7572 1E72 5803 3402 8001 BB02 BA95 C000 7D00 1600 0000 6B00 D600 BD00 00E0 1B00 7000 BD10 820C C010 AB10 0317 7D10 3A10 5110 EC10 FFFF F407 FFFF 3700 AFFF 00F0 4AFF 0D29 FFFF FFFF FFFF 7702 0002 FFFF FFFF 8300 3E00 E250 B0FF FFFF FFFF FFFF ------[ SMBus Device B00-D30 ]------ 0000 03 C0 40 00 00 40 00 00 FF FF FF FF FF FF FF FF ..@..@.......... 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF C0 40 00 00 40 00 00 FF FF FF FF FF FF FF FF ..@..@.......... 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF C0 40 00 00 40 00 00 FF FF FF FF FF FF FF FF ..@..@.......... 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF C0 40 00 00 40 00 00 FF FF FF FF FF FF FF FF ..@..@.......... 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D30 ]------ 0000 C003 40C0 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 C0FF 40C0 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 C0FF 40C0 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 C0FF 40C0 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D32 ]------ 0000 03 40 40 00 00 40 00 00 FF FF FF FF FF FF FF FF .@@..@.......... 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF 40 40 00 00 40 00 00 FF FF FF FF FF FF FF FF .@@..@.......... 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF 40 40 00 00 40 00 00 FF FF FF FF FF FF FF FF .@@..@.......... 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF 40 40 00 00 40 00 00 FF FF FF FF FF FF FF FF .@@..@.......... 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D32 ]------ 0000 4003 4040 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 40FF 4040 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 40FF 4040 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 40FF 4040 0040 0000 FF00 FF40 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D33 ]------ 0000 03 C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D33 ]------ 0000 C003 C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 C0FF C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 C0FF C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 C0FF C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D35 ]------ 0000 03 C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF C0 C0 00 00 C0 00 00 FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D35 ]------ 0000 C003 C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 C0FF C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 C0FF C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 C0FF C0C0 00C0 0000 FF00 FFC0 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D38 ]------ 0000 FF 62 A7 64 87 72 55 3F FF FF FF 00 00 FF FF FF .b.d.rU?........ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF 69 43 44 00 56 A1 ..........iCD.V. 0090 D0 05 A1 08 64 04 DD 05 FA 06 24 05 4A 04 0A 05 ....d.....$.J... 00A0 00 00 7D 11 00 00 00 00 FF FF FF FF 04 FF FF FF ..}............. 00B0 FF 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D38 ]------ 0000 FFFF 6262 A7A7 6464 8787 7272 5555 3F3F FFFF FFFF FFFF 0000 0000 FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6969 4343 4444 0000 5656 A1A1 0090 D0D0 0505 9B9B 0808 6464 0404 DDDD 0505 FAFA 0606 2424 0505 4A4A 0404 0A0A 0505 00A0 0000 0000 7D7D 1111 0000 0000 0000 0000 FFFF FFFF FFFF FFFF 0404 FFFF FFFF FFFF 00B0 FFFF 0000 0000 0000 0000 0000 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D40 ]------ 0000 FF FF FF FF FF FF FF 00 00 00 00 FF FF FF FF FF ................ 0010 FF 5A 5A FF 5A 5A 5A FF FF FF FF FF FF FF FF FF .ZZ.ZZZ......... 0020 FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF AA 48 30 00 56 EC ...........H0.V. 0090 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 1D 29 28 22 A8 A8 A8 FF FF FF FF FF FF FF FF 00 .)("............ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D40 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0000 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF 0010 FFFF 5A5A 5A5A FFFF 5A5A 5A5A 5A5A FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF AAAA 4848 3030 0000 5656 ECEC 0090 0000 0000 0000 0000 0000 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 1D1D 2929 2828 2222 A8A8 A8A8 A8A8 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0000 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D44 ]------ 0000 00 00 00 04 00 04 00 00 00 46 01 06 02 22 03 11 .........F...".. 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FF00 FF00 FF00 FF04 FF00 FF04 FF00 FF00 FF00 FF46 FF01 FF06 FF02 FF22 FF03 FF11 0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 ------[ SMBus Device B00-D51 ]------ 0000 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00 .....a@..%@..... 0010 0C 08 70 01 02 00 07 30 50 3D 60 3C 1E 3C 2D 01 ..p....0P=`<.<-. 0020 17 25 05 12 3C 1E 1E 00 06 3C 70 80 14 1E 00 00 .%..<....<p..... 0030 00 03 00 00 00 00 00 00 00 00 00 00 00 00 10 EE ................ 0040 7F 7F 7F 7F B0 00 00 00 02 4F 43 5A 32 52 50 58 .....OCZ2RPX 0050 38 30 30 45 42 32 47 20 20 20 20 02 AB 00 00 00 800EB2G ..... 0060 00 00 00 6D 56 4E A1 21 FF FF FF FF FF FF 88 25 ...mVN.!.......% 0070 10 28 1E 25 FF FF FF FF FF FF FF FF FF FF FF FF .(.%............ 0080 08 04 0B FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D53 ]------ 0000 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00 .....a@..%@..... 0010 0C 08 70 01 02 00 07 30 50 3D 60 3C 1E 3C 2D 01 ..p....0P=`<.<-. 0020 17 25 05 12 3C 1E 1E 00 06 3C 70 80 14 1E 00 00 .%..<....<p..... 0030 00 03 00 00 00 00 00 00 00 00 00 00 00 00 10 EE ................ 0040 7F 7F 7F 7F B0 00 00 00 02 4F 43 5A 32 52 50 58 .....OCZ2RPX 0050 38 30 30 45 42 32 47 20 20 20 20 02 AB 00 00 00 800EB2G ..... 0060 00 00 00 6D 56 4E A1 21 FF FF FF FF FF FF 88 25 ...mVN.!.......% 0070 10 28 1E 25 FF FF FF FF FF FF FF FF FF FF FF FF .(.%............ 0080 08 04 0B FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ Chips Found ]------ B00-D20: ON ASP0800 (Asus EPU2) Quote
Fiery Posted March 22, 2011 Posted March 22, 2011 If you want to override the automatic settings used to calculate core temperatures, go to AIDA64 / main menu / File / Preferences / Hardware Monitoring, and adjust TJMax temperature to 100 Celsius. Regards, Fiery Quote
