Marcel7355 Posted June 22, 2015 Posted June 22, 2015 What serial number android app shows to me? The serial number of my device starts with RF1D... characters, but AIDA android app show me another one. (see the pic). Thanks Quote
Fiery Posted June 22, 2015 Posted June 22, 2015 It shows the serial number that the device manufacturer (in your case: Samsung) has encoded in the Android profile of the device. Only Samsung knows what it may refer to It could be the actual device serial number, IMEI number, or even the MAC address of the WiFi or GSM adapter, etc. Regards, Fiery Quote
Marcel7355 Posted June 23, 2015 Author Posted June 23, 2015 ~ It shows the serial number that the device manufacturer (in your case: Samsung) has encoded in the Android profile of the device. Only Samsung knows what it may refer to It could be the actual device serial number, IMEI number, or even the MAC address of the WiFi or GSM adapter, etc.Regards,Fiery Yes. But manufacturer report me something like this: "We do not have any idea , what information is displayed by the other vendor's apps and where it had been taken". I think, this is serial for motherboard, not device itself. Quote
Fiery Posted June 23, 2015 Posted June 23, 2015 It was taken from Build.SERIAL, directly, there's no magic there at all. You can read more about that Android value at: http://developer.android.com/reference/android/os/Build.html#SERIAL It refers to it as hardware serial number, but as I've mentioned above, it's simply a value that the manufacturer of the device encoded there. It could refer to basically anything that the manufacturer chooses, or could even be a bogus value that is the same in every device. Quote
Marcel7355 Posted June 23, 2015 Author Posted June 23, 2015 It was taken from Build.SERIAL, directly, there's no magic there at all. You can read more about that Android value at: http://developer.android.com/reference/android/os/Build.html#SERIAL It refers to it as hardware serial number, but as I've mentioned above, it's simply a value that the manufacturer of the device encoded there. It could refer to basically anything that the manufacturer chooses, or could even be a bogus value that is the same in every device. I got it. Thank you. Quote
Marcel7355 Posted June 23, 2015 Author Posted June 23, 2015 It was taken from Build.SERIAL, directly, there's no magic there at all. You can read more about that Android value at: http://developer.android.com/reference/android/os/Build.html#SERIAL It refers to it as hardware serial number, but as I've mentioned above, it's simply a value that the manufacturer of the device encoded there. It could refer to basically anything that the manufacturer chooses, or could even be a bogus value that is the same in every device. I got the method for Samsung Galaxy Ace to get serial number: String serial = null; try if { Class<?> c = Class.forName("android.os.SystemProperties"); Method get = c.getMethod("get", String.class); serial = (String) get.invoke(c, "ril.serialnumber"); } catch (Exception ignored) { } Please, rewrite code for Samsung Galaxy Ace Smartphone in your next updates. Thank you so much. By the way, in ASUS MEMO HD7 tablet is everything OK. Serial is OK. PS. As I understood this method is for devices with Radio Interface Layer ("ril.*"). So that it's for you to think how check if the device supports telephony. And if so, display this method, but else dislpay another ("ro.*" or "sys.*") I tried make that in my project, and I had success. Quote
Marcel7355 Posted July 27, 2015 Author Posted July 27, 2015 Thank you, we'll check it out Serial number issue is still not fixed in new version Quote
Fiery Posted July 27, 2015 Posted July 27, 2015 Serial number issue is still not fixed in new version We will add RIL serial number information to the next AIDA64 for Android app update. Quote
