greetings,
I have a problem, I'm new here I hope this is the right board to post it.
pc loses power and restarts, this happens mostly while I'm watching stuff on VLC player, sometimes while doing nothing.
never happened while playing games.
I did a stability test for a few minutes and I'm posting the results. Maybe someone can spot something out of the ordinary.
The way the pc restarts makes me think its a voltage problem. But I'm no expert so I'm not sure.
my spec:
http://i.imgur.com/dlZl64K.jpg
any help is appreciated  :)
To me it doesn't seem to be a voltage issue. But I'm not sure what could it be :( It's not easy to diagnose such issues remotely, but maybe someone else here on the forums will have an idea...
I tried using windows diagnostic tool and it said to update my GPU drivers. So I did that
We'll see if it worked or not. I'll report here eighter way  :D
this is the error I'm getting at event viewer:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
  - Provider
      [ Name] Microsoft-Windows-Kernel-Power       [ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
      EventID 41       Version 2       Level 1       Task 63       Opcode 0       Keywords 0x8000000000000002     - TimeCreated
      [ SystemTime] 2015-07-27T09:42:41.436001700Z
      EventRecordID 110833       Correlation     - Execution
      [ ProcessID] 4       [ ThreadID] 8
      Channel System       Computer BAHA-PC     - Security
      [ UserID] S-1-5-18
- EventData
    BugcheckCode 59     BugcheckParameter1 0xc0000005     BugcheckParameter2 0xfffff88001727c1d     BugcheckParameter3 0xfffff880094b8930     BugcheckParameter4 0x0     SleepInProgress false     PowerButtonTimestamp 0
