Dschidi Posted August 17, 2015 Posted August 17, 2015 Hi, first of all thanks a lot for implementing the flow level, this is working fine for me (I just installed the latest beta but it also has been working using the last official version)! However ever since AIDA64 can show the flow level now the water level seems to be gone (the one showing how many % your reservoir is filled). It's not showing in the list of sensors in 5.30.3521 Beta, but also not in 5.30.3500. This certainly had worked in older versions before that weren't capable of showing the flow. Also I am pretty sure it's not that this sensor isn't showing because my water level is constantly at 0 Can you look into this please? kind regards, Dschidi Quote
Fiery Posted August 17, 2015 Posted August 17, 2015 Using the latest AIDA64 beta update (Build 3521) please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic. If you have Windows 10 installed, you may have to enable the status bar first, in AIDA64 / main menu / View. Please also let me know what water level does Aquasuite display. Thanks, Fiery Quote
Dschidi Posted August 17, 2015 Author Posted August 17, 2015 Thanks a lot for the super fast response! Here it is, the level in Aquasuite at the time I made the dump was 91.1% ------[ AIDA64 Extreme v5.30.3521 Beta ]------ ------[ Microsoft Windows 10 Professional 10.0.10240.16430 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-040215-Chipset$A1103161_BIOS DATE: 05/12/15 17:48:34 VER: 04.06.05 Motherboard Model : ASRock Z97 Extreme9 Motherboard Chipset : Intel Wildcat Point Z97, Intel Haswell DMI MB Manufacturer : ASRock DMI MB Product : Z97 Extreme9 DMI MB Version : DMI MB Serial : XXX-XXXXXXXXXXX DMI SYS Manufacturer: To Be Filled By O.E.M. DMI SYS Product : To Be Filled By O.E.M. DMI SYS Version : To Be Filled By O.E.M. DMI SYS Serial : To Be Filled By O.E.M. DMI BIOS Version : P1.70 ------[ DevClass / Human Interface Devices ]------ <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_02&col03#8&3abdffa6&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_02&COL03\8&3ABDFFA6&0&0002</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000004</ADDR> <DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_00&col02#7&297f640&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_00&COL02\7&297F640&0&0001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000008</ADDR> <DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_046d&pid_c714&col01#7&1b7abfeb&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C714&COL01\7&1B7ABFEB&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR> <DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_00#8&2eaa4e29&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_00\8&2EAA4E29&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000002</ADDR> <DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_01&col01#8&16e6c1e4&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_01&COL01\8&16E6C1E4&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_046d&pid_c714&col02#7&1b7abfeb&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C714&COL02\7&1B7ABFEB&0&0001</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_01&col02#8&16e6c1e4&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_01&COL02\8&16E6C1E4&0&0001</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c714&col03#7&1b7abfeb&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C714&COL03\7&1B7ABFEB&0&0002</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR> <DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c713#7&d0202c2&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C713\7&D0202C2&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000002</ADDR> <DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_01&col03#8&16e6c1e4&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_01&COL03\8&16E6C1E4&0&0002</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_046d&pid_c714&col04#7&1b7abfeb&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C714&COL04\7&1B7ABFEB&0&0003</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_01&col04#8&16e6c1e4&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_01&COL04\8&16E6C1E4&0&0003</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c714&col05#7&1b7abfeb&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C714&COL05\7&1B7ABFEB&0&0004</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c714&col06#7&1b7abfeb&0&0005#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C714&COL06\7&1B7ABFEB&0&0005</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c714&col07#7&1b7abfeb&0&0006#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C714&COL07\7&1B7ABFEB&0&0006</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR> <DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_01&col01#7&15c8127e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_01&COL01\7&15C8127E&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000009</ADDR> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_02#7&28f82ebc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_02\7&28F82EBC&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>0000000A</ADDR> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_02&col01#8&3abdffa6&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_02&COL01\8&3ABDFFA6&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000004</ADDR> <DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_00&col01#7&297f640&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_00&COL01\7&297F640&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000008</ADDR> <DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_01&col02#7&15c8127e&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_01&COL02\7&15C8127E&0&0001</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000009</ADDR> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_046d&pid_c52b&mi_02&col02#8&3abdffa6&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C52B&MI_02&COL02\8&3ABDFFA6&0&0001</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000004</ADDR> ------[ HID Device Info / HID-compliant consumer control device ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : aquaero System Control Serial Number : XXXXX-XXXXX Device ID : 0C70-F001 Usage : 0001h Usage Page : 000Ch Input Report Byte Length : 3 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant vendor-defined device ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : aquaero Device Serial Number : XXXXX-XXXXX Device ID : 0C70-F001 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 1038 Output Report Byte Length : 2114 Feature Report Byte Length: 2645 ------[ HID Device Info / HID-compliant system controller ]------ Manufacturer : Aqua Computer GmbH & Co. KG Product : aquaero System Control Serial Number : XXXXX-XXXXX Device ID : 0C70-F001 Usage : 0080h Usage Page : 0001h Input Report Byte Length : 2 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ Aquaero/Aquaduct Device ]------ Manufacturer = Aqua Computer GmbH & Co. KG Product = aquaero Device Serial Number = XXXXX-XXXXX Device ID = 0C70-F001 Usage = 0001h Usage Page = FF00h Input Report Byte Length = 1038 Output Report Byte Length = 2114 Feature Report Byte Length = 2645 ------[ AA5 Input Report ]------ Structure Version = 1200 Firmware Version = 2003 Bootloader Version = 102 Hardware Version = 6000 Device Type = 2 (Aquaero 5 XT / 6 XT) 0000 0C 75 E6 FF 04 B0 23 31 37 3E 07 D3 00 66 17 70 .u....#17>...f.p 0010 00 00 09 E8 00 94 40 0B 03 00 00 02 00 0F 00 00 ......@......... 0020 00 00 01 0C 75 DE 8D 00 00 00 02 04 00 FF FF 00 ....u........... 0030 07 D5 0F A0 03 DA 00 00 00 00 0C 01 93 62 FF D1 .............b.. 0040 FF D0 FF D0 FF CE FF CD FF CF FF CE 3C AC 03 44 ............<..D 0050 3B FB 01 96 00 D2 00 43 A6 18 00 49 6F 3A 65 A6 ;......C...Io:e. 0060 6B 1E 5C 72 0C A2 7F FF 7F FF 7F FF 7F FF 7F FF k.\r............ 0070 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 0080 7F FF 7F FF 0E 10 7F FF 7F FF 7F FF 7F FF 7F FF ................ 0090 7F FF 7F FF 0A F6 00 00 7F FF 7F FF 7F FF 0D 24 ...............$ 00A0 7F FF 0B 27 7F FF 7F FF 7F FF 7F FF 0A F6 7F FF ...'............ 00B0 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 0C DF 0C DF ................ 00C0 0B 57 0B 57 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF .W.W............ 00D0 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 00E0 7F FF 7F FF 00 00 16 E0 00 00 15 74 00 00 00 00 ...........t.... 00F0 00 00 00 00 00 00 00 00 00 00 00 00 7F FF 7F FF ................ 0100 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 01 93 7F FF ................ 0110 7F FF 7F FF 01 93 0C A2 0A F6 01 AC 00 C8 00 15 ................ 0120 FF FF 7F FF 7F FF 00 00 00 00 7F FF FF FF 7F FF ................ 0130 7F FF 00 00 00 00 7F FF FF FF 7F FF 7F FF 00 00 ................ 0140 00 00 7F FF 7F FF 23 95 7F FF 7F FF 7F FF 7F FF ......#......... 0150 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF ................ 0160 7F FF 7F FF 0D AC 02 04 0E B3 01 B9 00 3F 00 1B .............?.. 0170 00 32 02 22 0E 50 01 B4 00 00 00 00 00 00 00 00 .2.".P.......... 0180 00 00 00 00 00 00 00 00 00 00 00 00 27 10 04 B9 ............'... 0190 00 00 00 00 00 00 00 00 27 10 00 00 00 00 00 00 ........'....... 01A0 00 00 00 00 27 10 00 00 00 00 00 00 00 00 00 00 ....'........... 01B0 27 10 00 00 00 00 00 00 00 00 00 00 27 10 00 00 '...........'... 01C0 00 00 00 00 00 00 00 00 27 10 00 00 00 00 00 00 ........'....... 01D0 00 00 00 00 27 10 00 00 00 00 00 00 00 00 00 00 ....'........... 01E0 27 10 00 00 00 00 00 00 00 00 00 00 27 10 00 00 '...........'... 01F0 00 00 00 00 00 00 01 00 0E 88 04 C4 01 68 02 FF .............h.. 0200 FF FF FF FF FF FF 00 FF 00 00 FF FF FF FF 00 FF ................ 0210 00 00 FF FF FF FF 02 FF 00 00 FF FF FF FF 02 FF ................ 0220 00 00 FF FF FF FF 00 FF FF FF FF FF FF FF 00 FF ................ 0230 FF FF FF FF FF FF 40 00 00 3F 00 00 00 00 00 00 ......@..?...... 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 13 88 27 10 27 10 ............'.'. 0280 27 10 27 10 27 10 27 10 27 10 00 00 00 00 00 00 '.'.'.'.'....... 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 0D ................ 02E0 00 95 10 50 27 10 27 10 27 10 27 10 27 10 27 10 ...P'.'.'.'.'.'. 02F0 27 10 27 10 27 10 27 10 27 10 27 10 27 10 00 00 '.'.'.'.'.'.'... 0300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0310 00 00 00 00 00 00 00 00 00 00 00 00 00 00 27 10 ..............'. 0320 12 84 00 00 22 B4 27 10 00 00 22 B4 27 10 00 00 ....".'...".'... 0330 22 B4 27 10 00 00 00 00 00 00 00 00 00 00 00 00 ".'............. 0340 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 00 .......d........ 0350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0370 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0390 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0400 00 00 00 00 00 00 00 00 00 7A 52 A8 F8 .........zR.. Quote
Fiery Posted August 17, 2015 Posted August 17, 2015 Thank you, the issue will be fixed in the next AIDA64 beta update due in a few days from now. Quote
Fiery Posted August 24, 2015 Posted August 24, 2015 We've just rolled out the mentioned new AIDA64 beta update: http://www.aida64.com/downloads/latesta64xebeta Quote
Dschidi Posted August 24, 2015 Author Posted August 24, 2015 Thanks a lot, I just tested it and it's working fine! Now the water level is there and the flow level also and the numbers shown are the same as in aquasuite! Great support, much appreciated! Quote
