Missing PCH temperature sensor (Intel DP67BG)
Hi,
I've recently bought this motherboard and AIDA64 is only reporting VRM and DIMM motherboard temps., whereas the BIOS also shows a PCH temp. AIDA64 (1333 beta) lists the MB sensor as Winbond W83677HG / Nuvoton NCT677xF (ISA 290h).
Any chance of having the PCH temp. reported through AIDA please?
Thanks.
1) Please copy-paste the full content of the Computer / Sensor page into this topic.
2) Also, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic.
Hi Fiery,
Thanks for the quick response. Here you are:
Field Value
Sensor Properties
Sensor Type Winbond W83677HG / Nuvoton NCT677xF (ISA 290h)
GPU Sensor Type Diode, CHiL CHL8266 (NV-Diode, 46h)
Motherboard Name Intel DP67BG
Chassis Intrusion Detected Yes
Temperatures
CPU 26 °C (79 °F)
CPU Package 26 °C (79 °F)
CPU IA Cores 26 °C (79 °F)
CPU GT Cores 23 °C (73 °F)
CPU #1 / Core #1 23 °C (73 °F)
CPU #1 / Core #2 24 °C (75 °F)
CPU #1 / Core #3 26 °C (79 °F)
CPU #1 / Core #4 23 °C (73 °F)
VRM 30 °C (86 °F)
DIMM 31 °C (88 °F)
GPU Diode 29 °C (84 °F)
SAMSUNG HD103UJ 20 °C (68 °F)
Cooling Fans
CPU 1004 RPM
Rear 134 RPM
GPU 40%
Voltage Values
CPU Core 0.992 V
+3.3 V 3.392 V
+5 V 5.024 V
+12 V 12.160 V
+5 V Standby 4.994 V
South Bridge Core 1.048 V
DIMM 1.504 V
GPU Core 0.913 V
GPU +12V 12.109 V
GPU VRM 0.906 V
Current Values
GPU VRM 9.50 A
Power Values
CPU Package 7.31 W
CPU IA Cores 2.96 W
GPU VRM 8.50 W
Field Value
Sensor Properties
Temperatures
CPU 26 °C (79 °F)
VRM 30 °C (86 °F)
DIMM 31 °C (88 °F)
Cooling Fans
CPU 1004 RPM
Rear 134 RPM
GPU 40%
Voltage Values
CPU Core 0.992 V
+3.3 V 3.392 V
+5 V 5.024 V
+12 V 12.160 V
DIMM 1.504 V
GPU Core 0.913 V
GPU +12V 12.109 V
GPU VRM 0.906 V
Current Values
GPU VRM 9.50 A
Power Values
CPU Package 7.31 W
CPU IA Cores 2.96 W
GPU VRM 8.50 W
------[ AIDA64 v1.60.1333 Beta ]------
------[ Microsoft Windows 7 Professional 6.1.7601 (64-bit) ]------
Motherboard ID : BGP6710J.86A.1900.2011.0210.1012
Motherboard Model : Intel Burrage DP67BG
Motherboard Chipset : Intel Cougar Point P67, Intel Sandy Bridge
DMI MB Manufacturer : Intel Corporation
DMI MB Product : DP67BG
DMI MB Version : AAG10491-302
DMI MB Serial : BQBG05000141
DMI SYS Manufacturer:
DMI SYS Product :
DMI SYS Version :
DMI SYS Serial :
DMI BIOS Version : BGP6710J.86A.1900.2011.0210.1012
ITE 87xx Port = 00h
ITE 87xx Device ID = 0000h
ITE 87xx Version = 00h
Winbond SuperIO Port = 2Eh
Winbond SuperIO HWMonitor Port = 0290h
Winbond SuperIO Device ID = B473h
Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1
Fintek SuperIO Port = 00h
Fintek SuperIO Device ID = 0000h
LPC47 SuperIO Device ID = FFFFh
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0]------
0000 04 00 04 33 00 FF FF FF FF FF FF FF FF FF FF FF
0010 04 33 00 FF 00 FF FF FF 43 0F 00 00 23 FF 03 D7
0020 7B 5F D4 D4 9D 5E 83 21 00 2A FF DA 00 00 00 00
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0040 01 00 10 FF FF 00 3A 05 2D FF 00 00 18 95 03 A3
0050 FF FF 00 FF FF FF 00 80 C1 40 FF FF 01 08 08 05
0060 30 FF 40 01 01 01 00 FF FF FF FF FF 00 EE 4E FF
0070 00 0A 00 31 00 1B 00 31 00 FF 00 1F FF 01 21 00
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Reg$20 CPU Core: r = 123, r*0.016 = 1.97
Reg$21 CPU Aux: r = 95, r*0.016 = 1.52
Reg$22 +3.3 V: r = 212, r*0.016 = 3.39
Reg$23 +5 V: r = 212, r*0.016 = 3.39
Reg$24 +12 V: r = 157, r*0.016 = 2.51
Reg$25 -12 V: r = 94, r*0.016 = 1.50
Reg$26 -5 V: r = 131, r*0.016 = 2.10
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1]------
0000 0E 01 42 0A 0A 01 01 3C 00 00 FF 01 FF FF FF FF
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0020 02 01 37 37 40 43 46 00 00 00 40 80 FF FF FF FF
0030 FF 00 FF 00 02 72 00 FF 00 C1 02 01 40 34 FF 00
0040 00 FF 00 00 2F 00 00 00 01 FF FF FF FF FF 03 FF
0050 20 00 00 4B 00 50 05 FE FF FF FF FF FF FF FF FF
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2]------
0000 05 01 42 0A 0A 80 01 3C 01 33 FF 01 FF FF FF FF
0020 02 01 40 40 49 4C 4F 33 33 33 66 9A FF FF FF FF
0030 FF 00 FF 33 02 57 00 FF 00 C2 02 01 33 2A FF 00
0040 33 FF 33 33 1B 00 00 00 01 FF FF FF FF FF 03 FF
0050 1B 80 00 4B 00 50 18 00 FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3]------
0000 0E 01 42 0A 0A 01 01 3C 02 33 FF 01 FF FF FF FF
0020 02 01 37 37 40 43 46 33 33 33 66 9A FF FF FF FF
0030 FF 00 FF 33 02 72 00 FF 00 C1 02 01 33 34 FF 00
0040 33 FF 33 33 2F 00 00 00 01 FF FF FF FF FF 03 FF
0050 02 03 04 04 04 03 06 07 01 00 40 D9 41 0A 00 00
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4]------
0000 FF 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0010 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0020 FF 00 00 96 64 96 64 E1 96 01 FF FF FF FF FF FF
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 3F 00 03 FF FF FF FF FF FF FF FF FF FF FF 03 FF
0050 00 13 FF 00 00 00 00 2D 64 9E 19 33 09 5F 20 FF
0060 FF 01 00 00 00 00 00 00 FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5]------
0000 00 00 00 00 00 00 55 55 00 00 00 00 00 00 00 FF
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 03 FF
0050 CD C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6]------
0000 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF
0010 00 00 00 00 00 00 00 00 00 00 00 00 FF FF EC FF
0020 FF 01 02 05 0E 06 01 FF 00 00 00 31 00 21 04 00
0030 00 00 00 2A 01 34 00 00 00 00 FF FF FF FF FF FF
0040 FF 02 02 02 02 02 00 00 00 FF FF FF FF FF 03 FF
0050 7F 7F 7F 7F 7F 7F 00 00 03 EC 00 88 00 00 00 00
0060 00 31 00 01 00 00 00 00 00 00 00 FF FF FF FF FF
0070 7F 7F 50 4B 04 7F 7F 50 4B 04 7F 7F 50 4B 04 00
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7]------
0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00
0050 4B EC 00 10 3C A3 C4 84 80 64 09 68 22 0F 00 00
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0027 0150 0250 007D 0720
T: 33 32 29 1 0
T: 33 32 29 1 0
T: 33 32 28 1 0
T: 33 32 28 1 0
T: 33 32 27 1 0
T: 33 32 27 1 0
T: 33 32 26 1 0
T: 33 32 26 1 0
T: 33 32 27 1 0
T: 33 32 27 1 0
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
