Are the benchmarks optimized for Skylake yet? Since Skylake now allows you to adjust your BCLK freely, I went ahead and set it to 200 and halfed my multiplier. The result is a multiplier of 23 and a BCLK of 200MHz. Now, when I go to bench that with any of the AIDA64 benches, I seem to get incredible results for my hardware. Take this for example:
I've tried these two with a multiplier of 46 and the baseclock set to 100 its default value (100MHz) and I get around half of what I get with the BCLK set to 200MHz.
For the other benchmarks I do equally well, however, I haven't tried those with the multiplier set to 46 yet.
There's definitely an issue about using high BCLK setting on MSI and Asus motherboards. It's not about the benchmarks working off, they do work well actually. The benchmark results however are scaled by the CPU core clock value, and that's where there's a glitch.
We have to check the CPU registers to see where does AIDA64 go wrong about calculating the CPU core clock. Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic. If it's possible, please do that for both clock settings of 46x100 and 23x200.
------[ Versions ]------
Program Version : AIDA64 v5.30.3500
BenchDLL Version: 4.1.643-x64
------[ CPU Info ]------
CPU Type          : QuadCore Intel Core i7-6700K, 4600 MHz (46 x 100)
CPU Alias         : Skylake-S
CPU Platform      : LGA1151
CPU Stepping      : R0
Instruction Set   : x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2, FMA, AES
CPUID Manufacturer: GenuineIntel
CPUID CPU Name    : Intel® Core i7-6700K CPU @ 4.00GHz
CPUID Revision    : 000506E3h
IA Brand ID       : 00h  (Unknown)
Platform ID       : 3Dh  (LGA1151)
HTT / CMP Units   : 2 / 4
Max. NUMA Node    : 0
Tjmax Temperature          : 100 Celsius
HTC Temperature Limit      : 0 Celsius
CPU TDP                    : 95 W
CPU Max Power Limit        : Unlimited Power / Unlimited Time
CPU Power Limit 1 (Long)   : 4095.9 W / 8.00 sec  (Unlocked)
CPU Power Limit 2 (Short)  : 4095.9 W / 2.44 ms  (Unlocked)
Max Turbo Boost Multipliers: 1C: 46x, 2C: 46x, 3C: 46x, 4C: 46x
------[ Logical CPU #0 ]------
allcpu: Package 0 / Core 0 / Thread 0: Valid
CPUID 00000000: 00000016-756E6547-6C65746E-49656E69 [GenuineIntel]
CPUID 00000001: 000506E3-00100800-7FFAFBBF-BFEBFBFF
CPUID 00000002: 76036301-00F0B5FF-00000000-00C30000
CPUID 00000003: 00000000-00000000-00000000-00000000
CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00]
CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01]
CPUID 00000004: 1C004143-00C0003F-000003FF-00000000 [sL 02]
CPUID 00000004: 1C03C163-03C0003F-00001FFF-00000006 [sL 03]
CPUID 00000005: 00000040-00000040-00000003-00142120
CPUID 00000006: 000007F7-00000002-00000009-00000000
CPUID 00000007: 00000000-029C6FBF-00000000-00000000
CPUID 00000008: 00000000-00000000-00000000-00000000
CPUID 00000009: 00000000-00000000-00000000-00000000
CPUID 0000000A: 07300404-00000000-00000000-00000603
CPUID 0000000B: 00000001-00000002-00000100-00000000 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000000 [sL 01]
CPUID 0000000C: 00000000-00000000-00000000-00000000
CPUID 0000000D: 0000001F-00000440-00000440-00000000 [sL 00]
CPUID 0000000D: 0000000F-000003C0-00000100-00000000 [sL 01]
CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02]
CPUID 0000000D: 00000040-000003C0-00000000-00000000 [sL 03]
CPUID 0000000D: 00000040-00000400-00000000-00000000 [sL 04]
CPUID 0000000E: 00000000-00000000-00000000-00000000
CPUID 0000000F: 00000000-00000000-00000000-00000000 [sL 00]
CPUID 0000000F: 00000000-00000000-00000000-00000000 [sL 01]
CPUID 00000010: 00000000-00000000-00000000-00000000 [sL 00]
CPUID 00000010: 00000000-00000000-00000000-00000000 [sL 01]
CPUID 00000011: 00000000-00000000-00000000-00000000
CPUID 00000012: 00000000-00000000-00000000-00000000 [sL 00]
CPUID 00000012: 00000000-00000000-00000000-00000000 [sL 01]
CPUID 00000013: 00000000-00000000-00000000-00000000
CPUID 00000014: 00000001-0000000F-00000007-00000000 [sL 00]
CPUID 00000014: 02490002-003F3FFF-00000000-00000000 [sL 01]
CPUID 00000015: 00000002-0000014E-00000000-00000000
CPUID 00000016: 00000FA0-000011F8-00000064-00000000
CPUID 80000000: 80000008-00000000-00000000-00000000
CPUID 80000001: 00000000-00000000-00000121-2C100000
CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM]
CPUID 80000003: 37692029-3037362D-43204B30-40205550 [) i7-6700K CPU @]
CPUID 80000004: 302E3420-7A484730-00000000-00000000 [ 4.00GHz]
CPUID 80000005: 00000000-00000000-00000000-00000000
CPUID 80000006: 00000000-00000000-01006040-00000000
CPUID 80000007: 00000000-00000000-00000000-00000100
CPUID 80000008: 00003027-00000000-00000000-00000000
L1    Data Cache:    32 KB,  8-way Associative, 64-byte Line
L1  Instr. Cache:    32 KB,  8-way Associative, 64-byte Line
L2 Unified Cache:   256 KB,  4-way Associative, 64-byte Line
L3 Unified Cache:     8 MB, 16-way Associative, 64-byte Line
------[ Logical CPU #1 ]------
allcpu: Package 0 / Core 0 / Thread 1: Valid, Virtual
CPUID 00000001: 000506E3-01100800-7FFAFBBF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000001 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000001 [sL 01]
------[ Logical CPU #2 ]------
allcpu: Package 0 / Core 1 / Thread 0: Valid
CPUID 00000001: 000506E3-02100800-7FFAFBBF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000002 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000002 [sL 01]
------[ Logical CPU #3 ]------
allcpu: Package 0 / Core 1 / Thread 1: Valid, Virtual
CPUID 00000001: 000506E3-03100800-7FFAFBBF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000003 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000003 [sL 01]
------[ Logical CPU #4 ]------
allcpu: Package 0 / Core 2 / Thread 0: Valid
CPUID 00000001: 000506E3-04100800-7FFAFBBF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000004 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000004 [sL 01]
------[ Logical CPU #5 ]------
allcpu: Package 0 / Core 2 / Thread 1: Valid, Virtual
CPUID 00000001: 000506E3-05100800-7FFAFBBF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000005 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000005 [sL 01]
------[ Logical CPU #6 ]------
allcpu: Package 0 / Core 3 / Thread 0: Valid
CPUID 00000001: 000506E3-06100800-7FFAFBBF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000006 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000006 [sL 01]
------[ Logical CPU #7 ]------
allcpu: Package 0 / Core 3 / Thread 1: Valid, Virtual
CPUID 00000001: 000506E3-07100800-7FFAFBBF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000007 [sL 00]
CPUID 0000000B: 00000004-00000008-00000201-00000007 [sL 01]
------[ All CPUs ]------
CPU   0: APICID   0 / Package 0 / Core  0 / Thread 0: Valid
CPU   1: APICID   1 / Package 0 / Core  0 / Thread 1: Valid, Virtual
CPU   2: APICID   2 / Package 0 / Core  1 / Thread 0: Valid
CPU   3: APICID   3 / Package 0 / Core  1 / Thread 1: Valid, Virtual
CPU   4: APICID   4 / Package 0 / Core  2 / Thread 0: Valid
CPU   5: APICID   5 / Package 0 / Core  2 / Thread 1: Valid, Virtual
CPU   6: APICID   6 / Package 0 / Core  3 / Thread 0: Valid
CPU   7: APICID   7 / Package 0 / Core  3 / Thread 1: Valid, Virtual
------[ MSR Registers ]------
MSR 00000017: 0004-0000-0000-0000 [PlatID = 1]
MSR 0000001B: 0000-0000-FEE0-0900
MSR 00000035: 0000-0000-0004-0008
MSR 0000008B: 0000-0019-0000-0000
MSR 000000CE: 0008-0838-F101-2800 [eD = 0]
MSR 000000E7: 0000-0055-3838-FA2A [s200]
MSR 000000E7: 0000-0055-3D09-B886 [s200]
MSR 000000E7: 0000-0055-4173-6F90
MSR 000000E8: 0000-0056-1802-FBC1 [s200]
MSR 000000E8: 0000-0056-2736-233E [s200]
MSR 000000E8: 0000-0056-4366-DFB8
MSR 00000194: 0000-0000-000F-0000
MSR 00000198: 0000-2A8C-0000-2E00 [s200]
MSR 00000198: 0000-2BDB-0000-2E00 [s200]
MSR 00000199: 0000-0000-0000-FF00
MSR 0000019A: 0000-0000-0000-0000
MSR 0000019B: 0000-0000-0000-0010
MSR 0000019C: 0000-0000-8846-0800 [s200]
MSR 0000019C: 0000-0000-8842-0800 [s200]
MSR 0000019C: 0000-0000-8845-0800
MSR 0000019D: 0000-0000-0000-0000
MSR 000001A0: 0000-0000-0085-0089
MSR 000001A2: 0000-0000-0064-1400
MSR 000001A4: 0000-0000-0000-0000
MSR 000001AA: 0000-0000-0040-18C0
MSR 000001AC: < FAILED >
MSR 000001AD: 0000-0000-2E2E-2E2E
MSR 000001B0: 0000-0000-0000-0000
MSR 000001B1: 0000-0000-8844-0800
MSR 000001B2: 0000-0000-0000-0000
MSR 000001FC: 0000-0000-003C-005D
MSR 00000300: < FAILED >
MSR 00000480: 00DA-0400-0000-0004
MSR 00000481: 0000-007F-0000-0016
MSR 00000482: FFF9-FFFE-0401-E172
MSR 00000483: 01FF-FFFF-0003-6DFF
MSR 00000484: 0003-FFFF-0000-11FF
MSR 00000485: 0000-0000-7004-C1E7
MSR 00000486: 0000-0000-8000-0021
MSR 00000487: 0000-0000-FFFF-FFFF
MSR 00000488: 0000-0000-0000-2000
MSR 00000489: 0000-0000-0037-27FF
MSR 0000048A: 0000-0000-0000-002E
MSR 0000048B: 001F-FCFF-0000-0000
MSR 0000048C: 0000-0F01-0633-4141
MSR 0000048D: 0000-007F-0000-0016
MSR 0000048E: FFF9-FFFE-0400-6172
MSR 0000048F: 01FF-FFFF-0003-6DFB
MSR 00000490: 0003-FFFF-0000-11FB
MSR 00000601: 0000-0000-8000-0000
MSR 00000602: < FAILED >
MSR 00000603: 0036-0000-0036-3636
MSR 00000604: < FAILED >
MSR 00000606: 0000-0000-000A-0E03
MSR 0000060A: 0000-0000-0000-0000
MSR 0000060B: 0000-0000-0000-0000
MSR 0000060C: 0000-0000-0000-0000
MSR 0000060D: 0000-0000-0000-0000
MSR 00000610: 0042-FFFF-001B-FFFF
MSR 00000611: 0000-0000-0998-AE3C [s200]
MSR 00000611: 0000-0000-099A-01AA [s200]
MSR 00000611: 0000-0000-099B-964D
MSR 00000613: 0000-0000-0000-0003
MSR 00000614: 0000-0000-0000-02F8
MSR 00000618: 0054-00DE-0000-0000
MSR 00000619: 0000-0000-006C-56EE [s200]
MSR 00000619: 0000-0000-006C-683F [s200]
MSR 00000619: 0000-0000-006C-7A4B
MSR 0000061B: 0000-0000-0000-0000
MSR 0000061C: < FAILED >
MSR 0000061E: < FAILED >
MSR 00000620: 0000-0000-0000-0829
MSR 00000621: 0000-0000-0000-0029
MSR 00000638: 0000-0000-0000-0000
MSR 00000639: 0000-0000-0746-538F [s200]
MSR 00000639: 0000-0000-0747-6087 [s200]
MSR 00000639: 0000-0000-0748-4F82
MSR 0000063A: 0000-0000-0000-0010
MSR 0000063B: < FAILED >
MSR 00000640: 0000-0000-0000-0000
MSR 00000641: 0000-0000-0000-0000 [s200]
MSR 00000642: 0000-0000-0000-0010
MSR 00000648: 0000-0000-0000-0028
MSR 00000649: 0000-0000-0000-0000
MSR 0000064A: 0000-0000-0000-0000
MSR 0000064B: 0000-0000-8000-0000
MSR 0000064C: 0000-0000-0000-0000
MSR 00000690: 0000-0000-0000-0000
MSR 000006B0: 0000-0000-0000-0000
MSR 000006B1: 0000-0000-0000-0000
PerformanceFrequency = 3914060
CPU Clock M.Method = 7  (APIC NHM)
PM Timer Address   = 6152  (1808h)
APIC Clock = 100.00 MHz  (AT = 0 / TT = 0 / try = 0)
APIC Clock = 99.98 MHz  (AT = 0 / TT = 0 / try = 0)
APIC Clock = 100.05 MHz  (AT = 0 / TT = 0 / try = 0)
------[ OC MailBox ]------
C 01 / P1 00 / P2 00: 00000753
C 01 / P1 01 / P2 00: 0000073C
C 01 / P1 02 / P2 00: 00000753
C 01 / P1 03 / P2 00: 0000073C
C 02 / P1 00 / P2 00: 53535353
C 02 / P1 00 / P2 01: < FAILED >
C 05 / P1 00 / P2 00: 000186A0
C 10 / P1 00 / P2 00: 0000002E
C 10 / P1 01 / P2 00: 00000000
C 10 / P1 02 / P2 00: 00000000
C 10 / P1 03 / P2 00: 00000000
C 12 / P1 00 / P2 00: 00000000
C 14 / P1 00 / P2 00: 00000000
CPU Type          : QuadCore Intel Core i7-6700K, 9197 MHz (46 x 200)
CPU Stepping      : R0
Max. NUMA Node    : 0
CPU TDP                    : 95 W
Max Turbo Boost Multipliers: 1C: 23x, 2C: 23x, 3C: 23x, 4C: 23x
CPUID 00000015: 00000002-000000C0-00000000-00000000
CPUID 00000016: 000008FC-000008FC-00000064-00000000
MSR 000000CE: 0008-0838-F101-1700 [eD = 0]
MSR 000000E7: 0000-0040-CC40-CEE6 [s200]
MSR 000000E7: 0000-0040-CDF0-B4B6 [s200]
MSR 000000E7: 0000-0040-CFEE-9762
MSR 000000E8: 0000-003A-E877-0298 [s200]
MSR 000000E8: 0000-003A-E94D-74B9 [s200]
MSR 000000E8: 0000-003A-EAB2-F76F
MSR 00000194: 0000-0000-000F-1700
MSR 00000198: 0000-1DDE-0000-1700 [s200]
MSR 00000198: 0000-1D41-0000-1700 [s200]
MSR 00000198: 0000-1DE6-0000-1700
MSR 0000019C: 0000-0000-8845-0800 [s200]
MSR 000001AD: 0000-0000-1717-1717
MSR 000001B1: 0000-0000-883C-0800
MSR 00000611: 0000-0000-038F-35BB [s200]
MSR 00000611: 0000-0000-0390-7004 [s200]
MSR 00000611: 0000-0000-0391-85D2
MSR 00000613: 0000-0000-0000-0001
MSR 00000619: 0000-0000-0036-27E9 [s200]
MSR 00000619: 0000-0000-0036-388A [s200]
MSR 00000619: 0000-0000-0036-4974
MSR 00000620: 0000-0000-0000-1515
MSR 00000621: 0000-0000-0000-0015
MSR 00000639: 0000-0000-0291-BBF9 [s200]
MSR 00000639: 0000-0000-0292-4096 [s200]
MSR 00000639: 0000-0000-0292-E326
MSR 00000648: 0000-0000-0000-0017
PerformanceFrequency = 2249997
APIC Clock = 200.00 MHz  (AT = 0 / TT = 0 / try = 0)
APIC Clock = 200.05 MHz  (AT = 0 / TT = 0 / try = 0)
APIC Clock = 200.02 MHz  (AT = 0 / TT = 0 / try = 0)
APIC Clock = 199.95 MHz  (AT = 0 / TT = 0 / try = 0)
C 05 / P1 00 / P2 00: 00030D40
C 10 / P1 00 / P2 00: 00000000
C 10 / P1 01 / P2 00: 0000000B
C 10 / P1 02 / P2 00: 00000015
C 10 / P1 03 / P2 00: 0000000B
Thank you, that looks very interesting, and also quite odd. Please also post a screen shot of the CPU Tweakings panel, at 23x200 setting. Right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPU Tweakings.
I'd like to add that with the current version of the Asus BIOS I cannot read out my Vcore outside of the BIOS. I've read that this is a common problem and that Asus will fix it in a future iteration.
