Hi all :)
I'm new to the forums (and AIDA64) but I noticed something I wanted to share regarding a possible scripting issue.
When using the "static label" as part of the LCD items, if I select $MOBOMODEL and try to utilize a shadow, the actual motherboard model shows, however, the shadow shows the text "$MOBOMODEL" instead of matching the actual motherboard model.  This happens when using any of the "$" presets.  I believe it's important to note that I am using a custom font, however, I don't believe this is the issue.
Hope this helps the community as a whole.  Thanks in advance!
-d0ekun
