Hello,
ist there any implementation for reading the temperatures of MCP98243 Sensor Chips planed? My memory modules (Kingston 8GB 1333MHz ECC DDR3 Kit) use these chips for temperature readings.
Though i can check these temperatures with speedfan, it would be nice to have them integrated in aida64 too, as aida reads a lot more than speedfan.
k.r. oberst.
AIDA64 already supports DIMM TS temperature sensing for memory modules. However, you need to enable that feature in AIDA64 / main menu / File / Preferences / Stability. Make sure to restart AIDA64 after altering that option.
In case it doesn't work on your system, then please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full), and copy-paste the full results into this topic.
Hello,
i enabled the DIMM sensors, but it doesn't work (did a logout to ensure everything was closed). So here's the dump:
------[ AIDA64 v1.60.1339 Beta ]------
------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------
Motherboard ID : 12/06/2010-RD890-SB850-7A66DG04C-00
Motherboard Model : Gigabyte GA-890FXA-UD5 v2
Motherboard Chipset : AMD 890FX, AMD K10
Award BIOS Type : Award Modular BIOS v6.00PG
Award BIOS Message : GA-890FXA-UD5 F7c
DMI MB Manufacturer : Gigabyte Technology Co., Ltd.
DMI MB Product : GA-890FXA-UD5
DMI MB Version :
DMI MB Serial :
DMI SYS Manufacturer: Gigabyte Technology Co., Ltd.
DMI SYS Product : GA-890FXA-UD5
DMI SYS Version :
DMI SYS Serial :
DMI BIOS Version : F7c
------[ SMBus #0 ]------
SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port : 0B00
Can Have SPD: Yes
Scan Type : Full
------[ SMBus Device B00-D18 ]------
0000 00 00 00 00 00 C2 00 21 01 60 A3 2D 00 00 FF FF .......!.`.-....
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0000 EF00 0000 0000 0000 0000 74C2 5400 0121 0101 0160 01A3 902D 0100 0100 FFFF FFFF
0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D19 ]------
0000 00 00 00 00 00 C2 00 21 01 60 A3 27 00 00 FF FF .......!.`.'....
0000 EF00 0000 0000 0000 0000 B0C2 5400 0121 0101 0160 01A3 1727 0100 0100 FFFF FFFF
------[ SMBus Device B00-D1A ]------
0000 EF00 0000 0000 0000 0000 A8C2 5400 0121 0101 0160 01A3 1027 0100 0100 FFFF FFFF
------[ SMBus Device B00-D1B ]------
0000 00 00 00 00 00 C2 00 21 01 60 A4 28 00 00 FF FF .......!.`.(....
0000 EF00 0000 0000 0000 0000 90C2 5400 0121 0101 0160 01A4 1028 0100 0100 FFFF FFFF
------[ SMBus Device B00-D46 ]------
0000 01 3F 01 00 00 00 00 00 00 00 00 00 00 00 00 00 .?..............
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0000 3F01 013F 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0010 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0100
------[ SMBus Device B00-D50 ]------
0000 92 10 0B 02 03 19 00 09 0B 52 01 08 0C 00 3C 00 .........R....<.
0010 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 01 ixi0i. ...<<....
0020 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 24 01 ..............$.
0070 00 00 00 00 00 01 98 04 11 01 66 0D E6 38 F5 BA ..........f..8..
0080 39 39 36 35 34 31 33 2D 30 30 32 2E 41 30 30 4C 9965413-002.A00L
0090 46 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F ..............
00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A ...............Z
0070 00 00 00 00 00 01 98 04 11 01 66 0D 9A 38 F5 BA ..........f..8..
------[ SMBus Device B00-D52 ]------
0070 00 00 00 00 00 01 98 04 11 01 66 0C 90 AE F5 BA ..........f.....
------[ SMBus Device B00-D53 ]------
0070 00 00 00 00 00 01 98 04 11 01 66 0D D8 38 F5 BA ..........f..8..
Looks like the Memory modules are SMBus Dev. B00-D50 to 53 (i've got 4 Memory Modules).
k.r. Oberst.
