Run stress fpu aida 64. About 1 min received messege  Hardware Failure Detected test stopped.All temperature are normal.
my spec
i7 6700k
msi z170a gaming m5
cpu cooler ice hammer ih thor
memory DDR4 2X8GB 2666MHZ CORSAIR CMK16GX4M2A2666C16R RTL DIMM 288-PIN 1.2v
AEROCOOL STRIKE X  800 WATT
where is problem with my hardware
Try to update the BIOS to the latest stable one, and then restore all settings to the factory default. Maybe you've used excessive overclock for either the CPU or the RAM, and that made your system unstable.
